20 Most Recent Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV Questions & Answers
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Sony Grand WEGA... | Answered on Nov 23, 2018
Question shows tv is Sony KDF-60WF655.
Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen.
Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure.
Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem.
Did you replaced its lamp in last 2-3 years?
Thanks.
Sony Grand WEGA... | Answered on Oct 28, 2018
This video should help you.
Sony Grand WEGA... | Answered on Dec 04, 2017
I had this same problem and after doing some research, I removed the lamp, cleaned it and plugged it back in. It fixed my problem completely.
Sony Grand WEGA... | Answered on Mar 31, 2017
!!!IMPORTANT!!!
YOU MUST SEND ME YOUR LIGHT ENGINE AND I WILL REPAIR
CALL
801-920-7165
!!!IMPORTANT!!!
CALL
801-920-7165
ROBERTYOUR SONY LIGHT ENGINE WILL BE REFURBISHED WITH SONY ORIGINAL PARTS. THIS LIGHT ENGINE WILL LAST FOR MANY YEARS THE DEFECTIVE PART WILL BE REMOVED AND REPLACED WITH SONY ORIGINAL PARTS! SIMPLY SEND YOUR SONY LIGHT ENGINE TO ROBERT MILLAR 1426 23RD STREET OGDEN, UTAH 84401
THE DOCUMENTS BELOW WILL BE SENT STANDARD POST FOR YOUR RECORDS WARRANTY SIGNED IN INC BY ME ALSO A PROOF OF PURCHASE INVOICE.
Certificate of 6 MONTH WARRANTY
Item: Sony LCD Light engine
Customer Name_________________________
Warrantor Name__________________________
Robert Millar 1426 23rd street Ogden, UT 84401
Phone 801-920-7165
I warranty the Sony LCD panel with MY STAMP AND THE DATE OF INSTALLATION for the time period of 6 months
My signature________________________________
Estimated Date of installation_________________
THE DOCUMENT BELOW WILL BE EMAILED SAME DAY AS PURCHASE
PLEASE PLACE THIS DOCUMENT WITH YOUR SONY LIGHT ENGINE THAT YOU SEND TO ME
Certificateof Refurbishment, 06 MONTH WARRANTY
Please print your name_________________________
Please print your Email__________________________
Light Engine Serial Number _______________________
Calibration Description:
The optical block has three LCD panels red, green; blue the convergence is adjusted to a tolerance of 92%
Convergence formula;
Convergence = (The area of diverged grid @ 720p) /(Total area for converged red, green, blue gridline @ 720p) ? (100).
Technician name: ___________________________
Technician signature: ________________________
Date of calibration: ______________
Phone 801-920-7165
VISIT YOURSONYREFURB.COM
Sony Grand WEGA... | Answered on Apr 09, 2015
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Sony Grand WEGA... | Answered on Dec 15, 2014
Behind front panel.
Sony Grand WEGA... | Answered on Jun 10, 2014
You will probably need to replace the video card. Visit a PC repair shop for evaluation.
Sony Grand WEGA... | Answered on May 20, 2014
Those Rear LCD TVs get bad light engine on some. Causes fuzzy spots size of quarter. Or sharp small bright spots looks like road map or 'stars'. Need new/rebuilt light engine.
Sony Grand WEGA... | Answered on May 09, 2014
average 750 - 5000 hours depending on the bulb
Sony Grand WEGA... | Answered on Apr 22, 2014
Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV Logo
407 questions posted
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
tv turn blinks green red
  • Televison & Video
