I was pulling another mower and the trans just stoped working
Here is a YOUTUBE link:
Small Engine Repair Adjusting the Hydrostatic Transmission Control Arm on...
And WOW! Here are lots more!
husqvarna hydrostatic transmission adjustment Google Search
Anthony
Try PartsTreeRearClinic they may help
SOURCE: Honda Harmony mower, self propelled hydrostatic,
If i remember correctly, under each drive wheel, there is a small gear, and under each gear there is a small metal rod that is what the transmission uses to propel the mower...it sounds like the rods either have dirt on them or they are just stuck and can not move to allow you to pull it backwards
SOURCE: transmission stops pulling when it gets hot
when was the last time you had the trans serviced?
It could be seizing up from the lack of oil
SOURCE: Husqvarna, GTH2454T Hydrostatic power loss.
If it's like mine the transmission is sealed and cannot be serviced. A local repair shop told me most likely the problem isn't with the transmission but rather the engine pulley is worn. He said if sand or debris gets between the belt and the pulley which has a definite "V" shape to it that it will wear down to a "U" shape. Now mine has a foot clutch on the left side so he had me pull back on the pedal which manually tightens the belt. I did this and it works like a champ. This winter I'll change the pulley.
SOURCE: The charging system on the mower will not charge the battery up
The first thing to check on this machine is your voltage regulator try bypassing the voltage regulator to see if the alternator starts charging, it would be better to check your charging system with a voltmeter so that you know what the exact input and output in the electrical system.
SOURCE: Need manual for Murray 20'' 3.5 hp lawn mower
sounds like its running out of gas. I changed spark plug, still sounds like its about to die
