20 Most Recent Husqvarna 20HP Hydrostatic 42" Cut Riding Mower Questions & Answers
Only starts if mower lever engaged (without drive belt)
Sounds very strange but i would guess either a micro switch or one of the relays behind the dash.
12/18/2017 9:56:28 PM • Husqvarna 20HP... • Answered on Dec 18, 2017
When my mower runs for a while 20-30 minutes and gets warm it quits running, it will start again but then quits right away
Check the tank vent. Try loosening the fuel cap (not totally removed) see if this stops the problem. If so, try a new fuel cap.
12/12/2017 7:34:33 PM • Husqvarna 20HP... • Answered on Dec 12, 2017
Why wont my mower wont go up hill
Most likely the drive belt needs replacing.
7/13/2016 8:27:47 AM • Husqvarna 20HP... • Answered on Jul 13, 2016
What oil do I use in my ***** hydrostat?
Hydrostatic Transmission Fluid is actually 10W-50 synthetic motor oil (like mobil). Do not use hydraulic fluid or transmission fluid. Hydro static transmissions on most lawn tractors are very similar. Many of them are made by the same manufacturer. Tuff Torq makes a lot of them. They definitely make all the John Deere lawn tractor hydro drives. The lawn tractor manufacturers (like JD) often say they are sealed and not serviceable. That is flat out, a lie. All of the JD hydros, and most all others, are serviceable. A complete line of rebuild/replacement parts can be found at Tuff Torq. Info and instructions can be found there. It's quite likely they made your tranny too. Additionally, I have found that the mower manufacturers fill them (or spec them) with motor oil, 10W-30W. In the service manual, and at the hydro manufacturer, you are told if your tractor is used in extreme or heavy duty situations it's best to drain the oil and replace it with 10W-50 synthetic motor oil (like mobil). Truth is the tranny should have this oil from the get go. It will give you more power and extend the life of the tranny. The mower manufacturers are all just being cheap. They figure why not, you're the one who has to pay for the early failure. Oh yeah, one other minor detail, the tranny manufacturer also recommends regular oil changes, like every 100 hours. Virtually all of these trannys have a black plug on the top. You have to remove the tranny from the mower (not a difficult things to do, takes about 30 min). Pull that black plug and turn the tranny upside down for about 30 min to completely drain. Most hold about 2 quarts. Flip it back, right side up, and refill. Install plug and reinstall tranny. Note: under the plug there is often a magnet which collects metal shavings. Lift this magnet out while you have the plug out, clean it and replace it. It may fall out while the tranny is upside down. When you refill the fluid just keep filling till it comes up within a quarter inch of the plug. You may have to go through a bleed process after reinstalling the tranny. The tuff torq site explains the bleed process.
12/1/2014 4:55:18 AM • Husqvarna 20HP... • Answered on Dec 01, 2014
0answers
Why does my husqvarna riding tractor motion belt keep slipping off the pulleys?
They did not manufacture the pulley correct. The pulley lip is to short. What u need to do is bend the belt keeper so it just touches the belt on the idler pulley. I remove the pulley and keeper and give it a good bend. Then I adjust it into the correct position after reassembly. It doesn't have to rub on the belt.... just very close. That will do it.
5/10/2014 12:44:12 AM • Husqvarna 20HP... • Answered on May 10, 2014
My husqvarna riding lawn mower yth2148 makes loud
First of all I would replace the drive belt. It's amazing how many drive problems this fixes!
11/18/2013 11:11:50 AM • Husqvarna 20HP... • Answered on Nov 18, 2013
20hpstart circuit 20hp kohler husquvarner
I would start at the seat safety switch.
4/15/2013 5:18:01 AM • Husqvarna 20HP... • Answered on Apr 15, 2013
Husqvarna tire problems
Looks like you need to buy new tires.
5/1/2012 12:12:40 AM • Husqvarna 20HP... • Answered on May 01, 2012
Blade will not engage but all saftey features works
With the pto switch pulled out check with a multi meter that you have a 12 volt supply the the clutch, pull the connector apart at the clutch end to do this, if there is no supply it is a switch or wireing issue, if there is a supply, you shouls have an audible click when the pto switch is pulled out, this is the elecro magnetic clutch engaging, if the click is present, check the belt from the clutch to the deck.
3/7/2012 10:22:14 AM • Husqvarna 20HP... • Answered on Mar 07, 2012
Engine starts fine but when
Hi, most likely the safety switch on the seat is faulty. Hope this helps, regards Phil
6/25/2011 10:17:48 PM • Husqvarna 20HP... • Answered on Jun 25, 2011
My mower starts and the
The deck belt has to be checked. Either its out of line or its got loose / over stretched.------ Check the belt condition.Also check the hydrostatic clutch lever on the right that changes gears.Is the lever getting loose or any connections getting short from lever.------- If not, then belt has to be checked.-------- This will help.Thanks.Helpmech.
6/24/2011 3:29:34 PM • Husqvarna 20HP... • Answered on Jun 24, 2011
Husqvarna 20HP Hydrostatic 42" Cut Riding Mower Logo
Popular Tags
54 questions posted
Top Husqvarna Garden Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Thomas Perkins
Thomas Perkins
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
View Most Popular
Husqvarna Garden
  • Husqvarna Garden
Most Popular Question
blade will not engage but all saftey
  • Garden
