20 Most Recent
Husqvarna 450 e-series 18" Chain Saw Questions & Answers
My Husqvarna 450 won't idledown when warmed up
Verify carburetor linkage and throttle shaft are not sticking (remove linkage as a test). The intake and carb assembly are several components. There can be no air leaks at any point downstream of the throttle plate. Check mounting screws are properly torqued. Could also be crankcase leak. Check fuel tank is not building pressure (remove/loosen fuel cap as a test).
Husqvarna chain saw oiler problem
I fear you are correct about the oiler problem. I see a lot of oiler problems on these saws. Sooner or later Husky will have to address it. Ask the dealer about modifying your oiler; the 350 has an adjustable and might fit 1 or both of these saws. I think Husky needs to admit the nonadjustable is a mistake, and come up with a fix.
If you want to do some research start with the IPLs here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
Please post back (below) with what happens at the dealer. Take your buddy and his saw with you! Good Luck. HTH
Lou
If Husky starts modifying all these with 350 oilers I want compensation...LOL
Take cylinder head off
450 does not have a cylinder head. The cylinder assembly is one piece. The cylinder assembly is connected by 4 bolts installed from the bottom of the saw.
Primer ball will not take gas
Check to see if the primer is split or leaking. Then check your fuel filter and fuel lines. If all are clear and no leaks, the only other issue would be carburetor or lines installed incorrectly.
Wiring for 460 husqvarna
There is not much wiring on the 460. The coil has the lead to the sparkplug, then there is the ground (kill) wire running to the switch and grounded to the engine.
Not pumping oil
check oil pump, oil pump drive gear, and rubber oil guide tube isnt blocked
My oil reservoir is leaking
The grey plug in the base of the oil tank is the oil filter it will twist 1/4 turn and pull out, to replace push back in and turn 1/4 turn there is a leg on it that locks into the orange tank, there is a screw driver slot in it to assist this, they can be really tight try not to force too much or you will break it.
