When u thread the machine goes from spool of thread to a hook that goes down thread jumps out of that
SOURCE: Sewing Machine
check if you are using the original bobbin... There are some similar bobbins but they are not the same...
SOURCE: thread constantly wraps around spool pin
Cut a round curcle of fabric the size of the spool from a piece of felt. Put a hole in the middle and put it under the spool of thread. If this does not work you can purchase a small net that fits over the spool. It is designed to keep the thread from coming off the spool except for being pulled through naturally.
Hope this works.
Zelma
SOURCE: Threading my sewing machine
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
all machines thread the same. TTN tension, take up,
needle.
Beginning with the spool, guide the
thread through the thread guides to the tension assembly. Pull the thread
through the tension assembly and test it to make sure the tension is working
correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or
something in the middle. Raise the presser foot and pull the thread through the
tension. It should pull easily!! Lower the presser foot and pull the thread. It
should pull noticeably harder.) If it passes this test, continue up through the
take up lever,then down through the thread guides to the needle. Make sure your
needle is fully inserted and turned the correct way.( If you load your bobbin
case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT.
There are some exceptions. If you have a newer style drop in bobbin or your
bobbin case loads in the front then the rule is FLAT to the BACK.
Sewman7
SOURCE: No tension on my Singer 6212C sewing machine
Take the thread completly off the machine and rethread it making sure it goes thru the tension wheel properly.
FYI Loops on the bottom-- Problem is in the threadding.. Loops on the top, problem is with the bobbin.
SOURCE: have dificulty ftting the bobbin holder in a singer 974 machine
I need an illustration of the correct installation of a bobbin case for model 7422
