Heating & Cooling Logo
M
Mark Mosby Posted on May 11, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My air handler keeps trying to blow but keeps stopping the outside unit is working fine, it is an Amana unit.
Thomas Woodburn
Level 3:
  • Amana Master 2,638 Answers
  • Posted on May 11, 2018
Thomas Woodburn
Amana Master
Level 3:
Answers
2638
Questions
Helped
1252005
Points
7008
I would say you need a new fan motor.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
David Ellis Rhea
Level 3:
  • Amana Master 3,462 Answers
David Ellis Rhea
Amana Master
Level 3:
Answers
3462
Questions
Helped
786332
Points
10903
The most likely things, in order, are:
1) There is too much dirt, dust or lint clogging the squirrel cage fan, slowing it down and causing the motor to overheat and shut off.
2) The motor is clogged with dust or dirt and is overheating and shutting off.
or 3) the ductwork is clogged, causing the motor to overheat and shut off.
God bless your efforts.
5 Related Answers
Anonymous
  • 80 Answers
  • Posted on Dec 19, 2007
SOURCE: Replaced thermostat on FA4ANF030 with Honeywell model rth3100c does not work
if you have a newer t-stat your heat pump reversing valve is either o or b depending on the type of system you have
Anonymous
  • 104 Answers
  • Posted on Jul 02, 2008
SOURCE: Air handler only blows air for 3-5 minutes before shut off & not cycling frequently
Sounds like it could be a very weak run capacitor on the blower motor. Run capacitors are sized specifically to the needs of the motor. When a run cap gets weak, the motor trys to compensate for it by drawing more power. More power draw = more heat in the motor, then the motor will overheat and shut off to protect itself. When the motor cools off it will automatically restart and run until it overheats again. Keep in mind that I am a technician that normally diagnoses equipment in a hands on manner. There are many practices and concepts that transcend all air conditioning systems but it is a constantly evolving industry. I live in south eastern WA and I don't see Amana units except as window units. It is possible to have something else causing this problem (faulty thermostat, failing thermal relay(if used), problem with electronic controls(if used)) there are a lot of potential variables
Anonymous
  • 25 Answers
  • Posted on Nov 22, 2008
SOURCE: 1997 Amana 2 or 2.5 ton heat pump, 13 seer - air handler only blows 4-5 min
do you have a totaline t-stat. they and some other brands have a fan recirculation setting in the installers menu.
this is assuming that this happens in addition to the heating or cooling normally
Anonymous
  • 61 Answers
  • Posted on Jan 02, 2009
SOURCE: Only blows hot air inside
Set thr thermostat to AC instead of HEAT.
cactus bob
BOB BROWER
  • 267 Answers
  • Posted on Jan 24, 2009
SOURCE: fuse blowing on tappan air handler
most of the time its out by the ac unit . you have a shorting thermostat wire .. the outside unit has a large wire thats 240v and a small one that 24v thats the one you want to look at . look for bare wires , look where it goes into the wall , thats the common place . "critters" love to chew thermostat wire . so take a look . .....please rate this answer , i need votes . thanks
My air handler fan does not come on, the outside unit turns on fine. Is their a way to reset the fan?
Check for fan operation by turning the fan control at the thermostat to "on". If the fan blows, it works. If not, check a circuit breaker or fuse.
If the fan blows when forcing it on with the thermostat but not in automatic, check the fan control circuit in the air handler. Danger: high voltage, beware! There should be a system wiring diagram inside the air handler somewhere.
Keeps blowing 3 amp fuses when i turn the air conditioning on.
Ok, If 3 amp fuse is blowing in the air handler unit when switch is turned to cool check to see if outside unit jump starts and stops when this happens. If this is the case wiring is fine check main relay in outdoor unit. There will be a spring contact on main relay (Black relay close to where wires come into unit), check for corrosion or carbon build-up on little round contacts. If you can clean contacts with a small piece of sand paper. Make sure all breakers are off before removing cover! You might have to remove relay in order to clean it. Make sure you write down exact locations of any wires you remove. This should fix the problem.
1helpful
2answers
My A/C freezing its coils, while the fans keep running. The AC unit (outside) keep running and never stop caused the coils freezing. It doesn't matter when I turn off or set it to Cool position, the...
Sounds like the contactor in the condensing unit is stuck. That is why it will not turn off when the thermostat is satisfied. If the inside air handler is not blowing and the outside condensing unit is running, then this will cause the inside coils to freeze up rather quickly.
The contactor is located in the outside condensing uni in the electrical compartment.
If it is sticking it will need to be replaced.
1helpful
I had power blink off for a couple of seconds and then came back on. The Amana air conditioner RCC30A2E seem to be On but no cool air was blowing. I check breaker it was ok. I preceeded to check...
Check for fuses in the 24v wiring. Was anything running outside? The 24V X-former is located in the air handling unit. check for voltage on the air handler. if present, check output voltage at X-former. You should have 24V
1helpful
AC BLOWS WARM AIR
Cooling comes from what is done outside, if air handler is blowing and you are hearing a sound , may be in the duct work. If you feel warm air in cooling mode then the outside unit is the prob, need more info
2helpful
2answers
5helpful
2answers
Fuse blowing on tappan air handler
Top Amana Heating & Cooling Experts
Mike Cairns
Mike Cairns
Jay Finke
Jay Finke
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
