20 Most Recent Amana VTH12 12,000 BTU Vertical Terminal Air Conditioner System VTAC with Heat Pump and Choice of Back-up Electric Heater Size Questions & Answers
How are you determining that one section.is cold and one warm? If this is in fact the case you have a blockage in the coil or a compressor that is down provided this is a multi compressor unit.
Amana Heating &... | Answered on Feb 06, 2019
I'm leaning 2 directions, one is that your tstat is sensing your heatpump can not keep up with the load. Therefore bringing on heat strips or two, you have a cycles per hour limit set for compressor heating and your machine is cycling too often.
Amana Heating &... | Answered on Jan 27, 2019
F1 - Control Board Failure - Replace control board (ERC). F2 - Oven Temperature Too Hot - Replace oven temperature sensor. F3 / F4 - Shorted or Open OvenTemperature Sensor - Replace oven temperature sensor. F5 / F6 / F8 - Control Board Failure - Replace control board.
Amana Heating &... | Answered on Jan 20, 2019
Clean the filter and try it again
Amana Heating &... | Answered on Dec 31, 2018
I would guess two possible problems - dirty thermostat contacts and many appliances are also fitted with a thermal fuse or other type of thermal cutout which might have failed.
Amana Heating &... | Answered on Dec 13, 2018
How much power is the question. Remember, heating coils usually require 240 volts. You likely are only getting 115 due to a faulty limit switch. 115 will carry through to the other side of the switch from the coil side leading you to believe the switch is good. Remove both sides of switch and test continuity.
Amana Heating &... | Answered on Dec 12, 2018
Motor might be bad and shutting down on thermal protection. Is this a direct drive or belt driven ? .if belt driven try adjusting the belt tension or just replaced the motor
Amana Heating &... | Answered on Dec 11, 2018
What turns on the fan, a relay of its own, a defrost board, the compressor contractor? Check for power before and after the contacts. Read the lone or schematic diagram included with the unit if possible.
Amana Heating &... | Answered on Nov 01, 2018
It will be one of three issues. Blower motor is bad , capicator, or the control board. Easy enough to check . Use an extension cord , cut off the female end and strip it . You should have a black and white wire. Find the wires leading to the motor take the black and white off the control board conect black to black and white to white. Plug it in an outlet if the motor runs its the control board . If not its a bad motor or capicator. But caps rarely go bad in this use . So most likely motor . Not a hard job , but not eady if you dont have the right tools. Do not bang on the shaft with a hammer . You must use a special tool for pulling shafts.
Amana Heating &... | Answered on Sep 30, 2018
It is not switching from cooling into heating. You probably need to have a service tech look at the unit. Sorry. It could be control board or stuck reversing valve.
Amana Heating &... | Answered on Sep 26, 2018
Amana VTH12 12,000 BTU Vertical Terminal Air Conditioner System VTAC with Heat Pump and Choice of Back-up Electric Heater Size Logo
0 questions posted
Top Amana Heating & Cooling Experts
Donni Steen
Bill Long
Dennis Boxerman
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Amana Heating & Cooling
Most Popular Question
amana ams9 furnace flashing red
  • Heating & Cooling
