20 Most Recent Amana PTH123B25AJ Heat Pump Air Conditioner Questions & Answers
These unit need to tilt backwards so water can drain
Amana... | Answered on Dec 21, 2017
I don't think the Amana ASZ14 Heat Pump has a reset switch, but you can still reset it by resetting the power (when it's not running... turn your thermostat OFF first).
To reset the power, locate your circuit breaker box. There should be a double-breaker for the Heat Pump and another double-breaker for the Air Handler. Turn them both off for at least 2-3 minutes. Then flip them back on and turn your thermostat back ON.
You're thermostat may also have a RESET button that you can push. I have to reset mine every time I change the batteries in it.
Here are some more repair tips...
Heat Pump Troubleshooting & Repair:
http://www.hometips.com/repair-fix/heat-pump.html
Heat Pump Troubleshooting Repair
Amana ASZ14 web page:
http://www.amana-hac.com/products/heat-pumps/14-seer-asz14
ASZ14 Heat Pumps
Amana ASZ 14 SEER Technical Manual
(45-page PDF):
http://www.manualslib.com/manual/877256/Amana-Asz-14-Seer.html
Amana ASZ (and ASX) Service Instructions (66-page PDF):
http://www.acdirect.com/media/catalog/files/RS6200006.PDF
Amana... | Answered on Dec 16, 2015
provo te lidhesh direkt me spine 220 kompresorin
Amana... | Answered on Sep 18, 2015
either fan wheel loose on shaft or bad bearings in motor
Amana... | Answered on Sep 08, 2015
you would have to install line tap valves.
bad switch or motor.
use distilled water. clean system with bleach and water
If you reset the GFCI button and then when you go to turn it on the button pops again, then you have a short inside the units probably in the fan motor or the compressor..
heatman101
Amana... | Answered on Aug 30, 2015
subcooling is only a factor in the cooling mode. you convert the discharge psi to temperture and measure liquid line tempsrture. subtract difference it should be between 8 to 12 degrees.
Amana... | Answered on Aug 10, 2015
no its related to the outside condenser
Amana... | Answered on Jun 16, 2015
That's correct. If the piston opening is too large it will allow more frozen through than designed and flood the evaporator coil.
Amana... | Answered on Jun 10, 2015
the wall stat maybe bad. or wires to remote stat may be shorted
Amana... | Answered on Jun 01, 2015
You mean you are using the Emergency heat setting instead of the heat pump????...You're using Natural gas only now tn emergency heat????That's fine...I wouldn't replace a heat pump if you have Natural gas....it's too expensive compared to Gas....you may be able to still use the heat pump as an Air Conditioner only , it depends on what's wrong with it...otherwise you will have to get a Central Air unit instead...cheaper and just use the Gas for heat
Amana... | Answered on May 28, 2015
br means brown out protection engaged. Power was lost or voltage is to low, check for incoming power at correct voltage
Amana... | Answered on Mar 12, 2015
Outside temp too low, so outside thermostat and it's settings will not allow the heat pump to work. But insist on the ausilary heat to work instead. Heat pumps usually do not produce enough heat when below 40F outside temp. If you have Gas heat, it may be more economical than the heat pump below 40F. If electric auxilarry heat, it may compete at 32F. Talk to your dealer, installer, or manufacture.
Amana... | Answered on Mar 04, 2015
A bit more info would help - like "nothing as in switched off" or "nothing as in motors all running but nothing gets hot".
If you mean that it all sounds and looks as though it is working but there is no heat, then it is possible your changeover valve is jammed. There is usually a four way valve which effectively decides which way your a/c is going to be pumping.
Other reasons are that on this model, it checks to make sure there is at least a 5C difference before it will try and work.
For more help, please be a bit more descriptive as to what it IS doing as well as what it is not - eg: fans / compressor on? strange noises, hissing / error messages and also indoor / outdoor temps
Amana... | Answered on Jan 04, 2015
seems like 1995 3.5 ton unit
Amana... | Answered on Dec 21, 2014
Amana PTH123B25AJ Heat Pump Air Conditioner Logo
276 questions posted
Top Amana Heating & Cooling Experts
Donni Steen
Bill Long
WatsHVAC
Level 1 Expert
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Amana Heating & Cooling
Most Popular Question
large metering piston in indoor coil
  • Heating & Cooling
