20 Most Recent Amana AP095R Portable Air Conditioner Questions & Answers
2answers
Portable air conditioner rattling
not sure i use mine without exhaust hose
7/26/2022 11:46:24 AM • Amana AP095R... • Answered on Jul 26, 2022
2answers
Amana portable air conditioner
you need to empty the drain pan every couple of hours depending on the humidity level
8/17/2021 7:52:25 AM • Amana AP095R... • Answered on Aug 17, 2021
Power cord fused out.no power to unir.worked perfect last week.can it be fixed?
Anything can be fixed or replaced. Question is if it is cost effective to repair. If compressor is internally shorted, you just go out and buy a new ac since the cost of repair is more than that of a new one. Make sure that the short is not in the wire leading to the compressor before you go out and spend the scheckles.
6/12/2015 1:43:37 PM • Amana AP095R... • Answered on Jun 12, 2015
0answers
What coolent
Be the first to answer 7/22/2013 3:15:02 AM • Amana AP095R... • Posted on Jul 22, 2013Be the first to answer
0answers
Exhaust hose
Be the first to answer 7/20/2013 9:36:24 PM • Amana AP095R... • Posted on Jul 20, 2013Be the first to answer
0answers
Evaporation
Be the first to answer 7/7/2013 2:50:05 PM • Amana AP095R... • Posted on Jul 07, 2013Be the first to answer
0answers
Where does water that units makes while cooling go
never worked on one of these units my guess is evaporation
8/13/2011 9:14:14 PM • Amana AP095R... • Answered on Aug 13, 2011
Im an HVAC tech and
Deyonn, here's a link to the Owners Manual for the Amana APO95R Portable AC unit.
Once linked to the site, you can download and print the manual for future reference.
http://www.managemylife.com/mmh/owner_manuals/17647/AMANA-Air-Conditioner-Room-%2842%29-L0523054
Hope this helps you. Good luck!
7/6/2011 3:33:19 AM • Amana AP095R... • Answered on Jul 06, 2011
I have an Amana portable AC, Model # AP125D. When
This indicates a problem of electrical leakage inside your AC and it should be inspected by an electrician for your safety GFIs trip due to an imbalance of current between the 'hot' and neutral lines which means that current in traveling from the 'hot' line through some path to the ground (safety pin on the plug). If you use any method to fool the GFI (there are some) you should anticipate having nasty shocks from any exposed metal on the AC; not good idea.
If a professional finds no fault, it is quite possible that the GFI itself is failing; I have replaced several which were tripping on insignificant events.
6/22/2011 7:57:34 PM • Amana AP095R... • Answered on Jun 22, 2011
Air conditioner is rattling after
A few basic principles for air conditioner troubleshooting. For both central home air conditioner or window air conditioner, the first thing to check is whether the unit is getting proper power. If the unit uses 220 volt power be sure that the proper voltage is getting to the unit. Same for 110 volt units. A voltage meter can be used to assure that the voltage is correct.
For window air conditioning units the voltage can also be checked before and after the thermostat. If voltage is being supplied to the thermostat but not from it then the thermostat probably needs replaced. This is a fairly common problem. Another place to check is the fan motor voltage. The fan on window air conditioners runs both the indoor blower and the condenser fan. If that motor fails than the compressor may run for a short time, but will overheat and shut off. Continued operation like this will result in compressor failure. This motor can be economically replaced for larger window air conditioners, but for smaller ones the cost of replacement will be more than a new unit.
Central air conditioners for the home are more complex and there are more things that can go wrong. As with the window air conditioner the thermostat can also be a problem. The central air conditioner thermostat will only have 24 volts going to it. So don't look for high voltage there. Some units the voltage will be coming from the outdoor unit and others the voltage will be supplied by the indoor air handler or furnace. Most home central air conditioning will be supplied by the indoor air handler or the furnace. If the air conditioner is for cooling only the unit will usually have only two wires going to the condenser unit. Make sure that you have 24 volts across those wires.
The next thing to check will be the indoor blower. If your thermostat is calling for cooling then the indoor blower should be running. If there is no air moving across the indoor cooling coil then you will soon have a big block of ice formed on the coil. This can happen for a few reasons. The indoor blower is not working, the air flow is restricted and not allowing air to move across the coil. A clogged air filter would also do this. Or the outdoor condenser unit has lost the charge of refrigerant.
Finally and worst of all is when you have a complete compressor failure. Often when this happens the compressor will "lock up" or not be able to turn when power is supplied to it. Overheating or lack of lubrication are usually the main causes of compressor failure. Overheating can be caused by the outdoor coil around the compressor getting clogged with dirt, leaves, or grass. Loss of the refrigerant charge will also cause the compressor to overheat. It is the cool return gas coming back to the compressor that helps to keep it from overheating.
As you can see there are many things that can go wrong with an air conditioner and I have not come close to exhausting the possibilities here. I have just touched on the most common problems in a very basic way.
There are some basic trouble shooting things that can be done very easily. Most problems are above out of the range of comfort for many homeowners and professional help should be consulted before any attempt is made at repairs. Remember also, that the release of refrigerant gases into the atmosphere is a federal offense in the
US. Proper care must always be taken to minimize the release of any gases. A license is also required to handle refrigerants. Make sure that the professional you call has the proper certifications to handle refrigerants properly.
http://www.fixya.com/support/r3636709-size_air_conditioner_need
http://www.fixya.com/support/r3623253-window_air_conditioners_clean_every_year
http://www.fixya.com/support/r3633369-portable_air_conditioning_great_portable
http://www.fixya.com/support/r3623166-heating_air_conditioning_scams
http://www.fixya.com/support/r3597468-you_can_add_air_conditioning_to_your_hot
http://www.fixya.com/support/r3583697-how_to_keep_house_cool_without_using_air
6/7/2011 10:25:47 AM • Amana AP095R... • Answered on Jun 07, 2011
No power supplied when plugged in. The test button
It could be that. Or it could be a problem with the outlet it's plugged into. Check the circuit breaker panel for a tripped breaker. Also, check the outlet for interior damage or a loose wire connection.
In addition, if you haven't already, try plugging it into a different out on a different circuit.
Do this process of elimination, will tell you whether it's the AC unit or the outlet it's plugged into.
Hope this helps you troubleshoot and solve the problem.
6/2/2011 9:25:40 PM • Amana AP095R... • Answered on Jun 02, 2011
Amana AP095R Portable Air Conditioner Logo
40 questions posted
Top Amana Heating & Cooling Experts
Mike Cairns
Mike Cairns
Jay Finke
Jay Finke
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Amana Heating & Cooling
Most Popular Question
im hvac tech
  • Heating & Cooling
