SOURCE: Coffee Grounds
I would try cleaning out your coffee grinder first.
Here is the link to some helpful documents: http://www.cerinicoffee.com/Saeco_technical_documents.asp
Espresso machines and cleaning supplies
Visit www.CeriniCoffee.com
SOURCE: Why are my ejected coffee pucks very wet? Seems
First off is the a Delux model? If it is your Opti doser needs to be turned up a couple notches. Try turning it all the way to the + and then back off 1 click. Wet pucks have 2 solutions. Either the grind is too coarse or you don't have enough coffee in the brew unit to take up the air space and that leaves room for water.
SOURCE: Saeco talea touch - grinds & brews coffee into grounds drawer??
Try this, adjust the grind to a coarser setting atleast 2 numbers, then remove brew unit and look behind at white plastic valve, there is a small chamber under valve make sure chamber is clean and that the small discharge from chamber to drain tray is also clear. Then remove shower screen from brew unit and clean if necessary, also check the tube from the shower. Reinsert and test.
SOURCE: All water directed to Frother/ Water nozzle on Impressa C%
The Multivalve seems to be stuck. When you start up the machine you should hear the multivalve turning 2 times, if it`s silent, the valve is defective. This valve is important to guide the water in the right direction. Contact your servicedealer and let them have a look. There`s also a small chance that the electronic board are sending wrong or no signals to the valve
SOURCE: There seems to be water leaking somewhere. the
Is it clean water or dirty coffee water?
If clean then there is a leak on the boiler or one of the water lines.
If dirty coffee water, then remove the brew unit and clean the small chamber under the white plastic valve.
