20 Most Recent Bosch Tassimo TAS4511UC Coffee Maker Questions & Answers
3answers
Tassimo low water light will not reset
The problem is because Tassimo water tanks have a floating magnet in them which operates the water level switch inside the body. The magnet gets weak over time. Replacement tanks cost too much to be worth the cost. The simple answer is to stick a fridge magnet on the back of the unit (just above the power switch) using blue tack or similar (you can experiment to find the right position). Our unit has been working fine like this for a few years now. :-)
9/19/2021 2:11:08 PM • Bosch Tassimo... • Answered on Sep 19, 2021
10answers
Hi... amber light stays on, machine won't work
Be sure the bar code is clean and the reader screen it rests on is clean as well. I found if the coffee maker leaked some coffee or milk within the unit it sometimes covered the bar code or reader and prevented the machine from reading the code.
7/6/2021 7:36:21 AM • Bosch Tassimo... • Answered on Jul 06, 2021
Fix water level censor tassimo
Check to e if the magnet in the reservoir is moving up & down if not then try to place a magent on the back of the machine
5/26/2021 9:37:48 PM • Bosch Tassimo... • Answered on May 26, 2021
2answers
The yellow light stays on
clean the optical sensor that reads the barcode with a non abrasive cleaner. Mine needs to be "wet" before reading the bar code as well as the plastic of the sensor seems to be permanently cloudy. Horrible as it sounds i lick my finger, wipe the sensor and then close the lid. Usually works!
12/31/2020 8:07:54 AM • Bosch Tassimo... • Answered on Dec 31, 2020
3answers
Tassimo red light stays on
After many months, I solved the problem of the red light staying on the Tassimo Coffee Maker. Use these easy steps.
1. Fill a 2 cup measuring cup with hot water.
2. Mix in descaler.
3. Pour in the empty water tank.
4. Put the yellow cleaning disk in the chamber and close chamber. Put the two cup measuring cup under the spout.
5. Push and hold the brew button for about 3 seconds (until the red and green light flash.
6. Now don't touch the machine. It will do it's thing for about 20 minutes. (Don't be impatient and start to push buttons, just leave it)
7. When it finishes it's cycle. The red light will turn off. Then clean the water tank and put fresh water and run clean water through the brewing cycle 4 times. Your machine is now ready for use.
4/28/2020 8:04:17 AM • Bosch Tassimo... • Answered on Apr 28, 2020
Hi the spring at the back where water is,has come out does anyone know how to fix it pease
Hi how to open Plastic side of Bosch coffee machine tas4503gb/ 02
1/21/2019 5:48:20 PM • Bosch Tassimo... • Answered on Jan 21, 2019
Where can i buy water filters?
Great question! When it comes to filtering water it's always the best option to gather such information before buying any filters. The water filter will provide healthy water which protects the body from disease. Even more, Water filters greatly reduce the risk of rectal cancer, colon cancer, and bladder cancer by removing chlorine and chlorine byproducts from drinking water. So I suggest, If you want to stay healthy then you should buy the water filter from the most reliable company. & The best choice of pure Alkaline water Ionizer is Alkaviva. You can find a variety of water filters. Alkaviva is the best water ionizer company which manufactures reliable & excellent water Ionizers. Water Ionizers USA Made Filters and Hydrogen Generators
10/4/2018 4:59:09 AM • Bosch Tassimo... • Answered on Oct 04, 2018
Water won't heat up in my bosch tassimo coffee
I unfortunately got my vivy emesred in water. When I switch it on it stars brewing cold water splashing all over the place and does not stop!
Any idea how I can salvage the machine?
1/27/2018 5:41:01 PM • Bosch Tassimo... • Answered on Jan 27, 2018
3answers
Fill tank light stays on and water doesn't brew.
You need to remove the tank and empty the water inside. Then open the small cartridge that contains the floater and insert the small round magnet back in its place in the middle of the floater.Assemble the tank and it should be working fine!
1/3/2016 1:53:41 AM • Bosch Tassimo... • Answered on Jan 03, 2016
2answers
The red light won't go off even after refilling the water tank and changing the filter
Which red light? The descale light or the water level light? both are red. If the first, you need to go through the descale process as described in http://www.manualowl.com/m/Bosch/TAS4511UC/Manual/216487 If the refill lamp lights, there may be a fault, but try the descaling process anyway.
12/20/2015 9:04:20 PM • Bosch Tassimo... • Answered on Dec 20, 2015
Where can i buy replacement
Hi, you can purchase replacement parts at amazon, click here and take a look: Braun Piercing Unit. Cheers
1/6/2015 5:32:30 AM • Bosch Tassimo... • Answered on Jan 06, 2015
Bosch Tassimo TAS4511UC Coffee Maker Logo
226 questions posted
Top Bosch Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
David Kassin
David Kassin
vince
Are you a Bosch Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
TASSIMO Bosch
  • TASSIMO Bosch
Most Popular Question
tassimo low water light will not reset
  • Coffee Makers & Espresso Machines
