20 Most Recent
Saeco Spidem Villa Questions & Answers
Seaco spidem villa machine
Take off the top and check the fuse, if you have the old version off your machine you will find the fuse on a wire, if you have a new version then you have to reset the thermostat on the boiler (two pcs).
Hope this will help you.
/Mirran
My Saeco Spidem Villa leaks after it despenses the
Take out the grounds box and the brew group. At the back there is an opening. If grounds get in the opening, it can't drain. Get some hot water in a squirt bottle and flush out that opening at the back ... this may end your problem with leaking after dispensing
How to stop water leak from tank
Go to saeco phillips on line and order a new seal that is mounted on the machine under a small plastic cover where the water tank conects to the machine
