20 Most Recent Solis Master 5000 Espresso Machine Questions & Answers
It is stuck in mode and I can't get the brew group
Hi
First off put everything back in the machine (drip tray, dredge drawer, and push the brew unit in till you hear a click) then close the door. Turn on the machine and see if it moves. If it doesn't, then try this.
Remove the dredge drawer. Open the door. On the left side of the brewing unit, and towards the back of the brew group, there is a single screw. Remove the screw. Grab the handle and pull carefully, but firmly with a quick ****. The brew group should come out. There is a piece that remains in the machine. Slide the piece down and to the right and it will come off. Insert the piece into the hole on the backside of the brew group with the clip up. Tighten the screw and move brew group back into position. If your brew group did not come out please give us a call.
To return the brew group to the centered position, you first need to drop the funnel. To do this, look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and to the center. If you look down through the funnel you should see a piston. This should be centered in the funnel. If not, locate the slide on the left side of the brew unit,( it should be hanging down, a flat rectangular piece attached to the cylinder) and push the slide to the right until it does. Push the press button and you are now ready to reinsert the brew group in to the machine. First you must close the door and turn on the machine without having the brew group in. You will hear the motor turn on and when it stops completely, open the door and remove the tray, now insert the brew group and replace the tray.
10/18/2018 5:25:17 PM • Solis Master... • Answered on Oct 18, 2018
0answers
Smoke!
Be the first to answer 8/3/2017 12:12:02 PM • Solis Master... • Posted on Aug 03, 2017Be the first to answer
0answers
How can I determine what parts I need to repair my espresso machine and where do I get parts and service?
Solis Master 5000 Espresso Machine - YouTube
? 9:49 www.youtube.com/watch?v=MjBmlQXElag Sep 2, 2010 - Uploaded by Day Tooley I have been enjoying the Solis Master 5000 for a year. It's time to ... I haven't been able to find an actual user manual online...for some reason.
11/3/2015 1:55:24 AM • Solis Master... • Answered on Nov 03, 2015
Will not power up?
Wall outlet have power? Is the power cord good? Sometimes they get tired. Is the power on switch good? Etc. It is possible the internal heating element and it's controls are bad.
5/12/2015 5:07:38 PM • Solis Master... • Answered on May 12, 2015
4answers
Parts for Solis Master 5000
Jimle's reference to www.partsguru.com is where I found what I needed. The challenge was figuring out that the parts for your Solis Master 5000 will be referenced under the Vienna model. You will not find any reference to the Solis model on this website. But there are parts for out Solis machines, heres a link for the boiler gasket:
http://www.shop.partsguru.com/product.sc?categoryId=-1&productId=282
here's the link for a completed boiler replacement $38.00:
http://www.shop.partsguru.com/product.sc?categoryId=-1&productId=937
I ordered the completed boiler at $115.00
Good luck and Best Wishes
Lane
12/4/2014 8:43:21 AM • Solis Master... • Answered on Dec 04, 2014
Question for Solis Master 5000 Digital. After being professionally repaired, it has worked fine for about 2 months, and then suddenly stopped brewing coffee. I cleaned it.Then I decalcified it using i
I am not familiar with the digital model. But it sounds like something didn't get put back together properly. The top mesh is very tricky and easy to strip if you took it apart to clean. I had a problem with mine and now just leave it on and wipe it off in place. If its not tight water will just bypass the coffee grounds. Sorry, I couldn't be more help
7/10/2014 5:39:40 AM • Solis Master... • Answered on Jul 10, 2014
0answers
Solis Master 5000 Espresso Machine Logo
139 questions posted
Top Solis Coffee Makers & Espresso Machines Experts
Sulejman Sulejmani
Sulejman Sulejmani
Mike Cairns
Mike Cairns
ADMIN Eric
ADMIN Eric
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Solis Coffee Makers & Espresso...
  • Solis Coffee Makers & Espresso...
Most Popular Question
ventilate
  • Coffee Makers & Espresso Machines
