20 Most Recent Gaggia Titanium Espresso Machine Questions & Answers
Hi If you remove the brew unit and put everything back with out it the brew unit. Turn th machine on and see if it will cycle? Open the door and look in the back where the brew unit was. There is a cog in the back with teeth. There are 2 large teeth, and they should be at the 10 and 12:00 position roughly. If they are anywhere else you have a broken drive and need to get the gears replaced. If they are in the correct position check the front of the brew unit where the circles are. There are 2 diamonds and they should be pointing at each other. if they are not you need to bring them together with the key tool. Insert it into the center of the circles and turn until they line up, then put back into the machine, and see if it will work. If it still doesn't you have a bad board.
Gaggia Titanium... | Answered on Jun 19, 2019
hello in the water tank they is a float it was probably out of water for a while and the float is stuck take the container in our hand and tap it gently by doing that the float gonna get loose move the container you gonna ear the float move put it back fill with water enjoy cheers
Gaggia Titanium... | Answered on Mar 07, 2019
The beans are hanging up in the hopper and not falling down into the grinder...... wiggle it, give the beans a push, or go to a bean that is not so sticky....
Gaggia Titanium... | Answered on Feb 01, 2019
Try first unplugging power cable for five minutes, see if this reset machine.
Gaggia Titanium... | Answered on Jun 30, 2018
Look at the sensor for the door to see if there is any broken plastic pieces or perhaps the sensor has come loose and just needs adjusting.
Gaggia Titanium... | Answered on Feb 13, 2018
the steam valve is most likly plugged with sacale or such have you decaled the machine latly may want to start there
Gaggia Titanium... | Answered on Nov 17, 2017
Me too - machine unusable
Gaggia Titanium... | Answered on May 16, 2017
Gaggia Titanium Espresso Machine Logo
703 questions posted
Top Gaggia Coffee Makers & Espresso Machines Experts
Pierre Laplante
Ekse
Marvin
Marvin
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Gaggia Coffee Makers & Espresso...
  • Gaggia Coffee Makers & Espresso...
Most Popular Question
fill watertank message appears even
  • Coffee Makers & Espresso Machines
