Samsung tv tuner monitor having issues turning on, when the power is turning on the power led comes on then starts blinking with a clicking sound like the power is turning on and off. have tried chnging the source like turning on in tv mode but still same result, the hardware in computer itself is fine i have double checked the symptoms look like the power button is short circuited and its going on and off...any help?
Hello
I am a technician-informatic. I have repaired about 80 Lcd Samsung monitors with theese problems. I offer the repair manual.
Manual has been done with the experience of the repairing Samsung Lcd monitors. Manual was made by me and shows how to open monitor, how
to solve dark screen problem, how to check and replace capacitors, how to solve the problem non-optimal mode (without reprogramming MCU or
changing the main board) photo are included. 100% functional. The repair process is very simple 30-40min. (does not need a lot of
experience in electronics and expensive instruments) and is not expensive. With this manual you can solve problems by yourself and save
money.
"Not Optimum Mode 1280x1024 60Hz"
- The monitor turns on but turns off by itself, the LED blinks green.
- If you detach from the PC points to "control cable" the picture runs continuously in the vertical direction or presents while line , and
as soon as it is reconnected, the monitor goes off.
- The monitor does not turns on and dont dispaly anything, the LED blinks green-lit, if you detach from pc points to "control cable".
- The monitor turns on, works well some time, but after a window apiers "Not optimum mode. Mode recommended 1280X1024 60Hz"
- The monitor turns on, works well only with low resolution 800x600, when try to change a window that reads "Not optimum mode. Mode
the manual you can find on ebay (my ebay name is asnerejas123):
Samsung monitor repair manual guide 710n,913v,510n more
220498646211
Riparazione - repair Lcd Samsung monitor 710n,913v,510n
220498645860
Reparaturhandbuch für Samsung 710n,913v,510n und andere
220499443698
Its a general fault however all these units are under a 3 year warrantee the dates printed on the back, just call 08706010309 speak to a service engineer and they will arrange a swap out within 5 working days, no need to a receipt as they can tell the units age from the serial. the replacement will be under the same 3 years cover in my case it was for another 6 months
mine has started to do exactly the same the green power led blinks and you can hear a faint clicking sound
Same problem her, also the monitor seems to have problems with external sources
Can you clarify the phone number.. 0870 ?
