20 Most Recent
Samsung SyncMaster 940MW 19 in. LCD Television Questions & Answers
I have TV/Monitor Samsung 940mw. it is having
The power-up problem you are having is usually caused by a failing power supply board. There are parts called capacitors that will exhibit this type of problem until they are warmed up. As time goes but after they start failing they will take longer and longer for the power supply to stabilize before you get a picture. If you can solder then you should be able to do the repair yourself. We have a step by step repair guide that should get you going posted on our site at:
http://www.ccl-la.com/blog/index.php/repairing-the-samsung-940mw-lcd-tv/ If you don't want to do the repair yourself, we do offer a repair service for this model. The repair runs $35 plus shipping and can be setup at:
http://www.ccl-la.com/blog/index.php/service-request-form/I hope this helps, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
7/12/2010 3:57:24 AM •
Samsung...
Answered
on Jul 12, 2010
Hi My Syncmaster 940MW LCD,is cutting out and
Power supply board is dead.Replaced the power supply board should solved this problems.Tries Websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for replacement.
2/13/2010 10:14:17 AM •
Samsung...
Answered
on Feb 13, 2010
Syncmaster 940mw , there is no power
I have the same problem. I dismantled it, and there are broken/exploded capacitors on the power panel. If you replace these, it will fix the problem.
1/19/2010 10:24:43 PM •
Samsung...
Answered
on Jan 19, 2010
It does not turn on
If the power is properly connected and you're getting the button to light up then it is possible your backlight or inverter board is shot.
1/19/2010 10:23:18 PM •
Samsung...
Answered
on Jan 19, 2010
Would an inverter from a Samsung Syncmaster 910MP work in a Samsung Syncmaster 940MW?
The Samsung SyncMaster 940MW monitor has an issue with the power supply # IP-46135T going out. The flashing power light or not turning on are the classic symptoms of this issue. Check out our web site at:
www.ccl-la.com We have a step by step repair guide posted that will guide to doing the repair yourself. It involves changing a few capacitors on the power supply. If you can solder then you should be able to do the repair yourself. If you don't want to do the repair we do offer a repair service for $35 plus return shipping. If you have any additional questions just let us know at:
[email protected]I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
1/19/2010 10:20:28 PM •
Samsung...
Answered
on Jan 19, 2010
Problems with Samsung SyncMaster 940MW 19 in. LCD
The Samsung SyncMaster 940MW monitor has an issue with the power supply going out. The flashing power light or not turning on are the classic symptoms of this issue. Check out our web site at:
Buddy
Corporate Computer
www.ccl-la.com
1/19/2010 10:05:42 PM •
Samsung...
Answered
on Jan 19, 2010
Samsung 940mw monitor ringing then blank screen
www.ccl-la.com Look on the monitor repair page 2. We have a step by step repair guide posted that will guide to doing the repair yourself. It involves changing a few capacitors on the power supply. If you can solder then you should be able to do the repair yourself. If you don't want to do the repair we do offer a repair service for $35 plus return shipping. If you have any additional questions just let us know at:
Buddy
Corporate Computer
www.ccl-la.com
1/19/2010 10:04:03 PM •
Samsung...
Answered
on Jan 19, 2010
Monitor Screen
It may be that the scan rate is not matched. Check that the resolution and refresh rate from the computer is set to be in the exact native mode for the TV screen.
Jerry G.
4/20/2008 6:55:29 PM •
Samsung...
Answered
on Apr 20, 2008
Need the adapter for the non standard cable connector on the back of 940mw
Your Samsung SM940MW supports multiple TV and video signal formats including NTSC, PAL, and SECAM making it multi-system.
The aerial/cable input follows the European standards. What you described as "screw on connector that has a female center" is better known as a "PAL" connector whereas the US uses the "FP". What you need then is a female FP-5 to male PAL adapter.
This
page would list most of the common adapters for such a purpose. Perhaps you can print it out and show to the salesperson when you go looking for one.
Hope this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
11/15/2007 1:45:20 AM •
Samsung...
Answered
on Nov 15, 2007
Missing cable channels
You need to contact your cable service provider about this, it is a signal issue not a TV issue.
4/25/2017 9:55:47 PM •
Samsung...
Answered
on Apr 25, 2017
