20 Most Recent
Samsung SyncMaster 710N 17" LCD Monitor Questions & Answers
Samsung 710n
Press menu button for more than 10 sec. Afterwards OSD menu should be unlocked.
Good luck
9/16/2019 1:20:30 AM •
Samsung...
Answered
on Sep 16, 2019
No display on SyncMaster 710N
I used 2 resistor of 100 ohms (1/8W) to make one of 50 ohms. Like others instruction, just put the 50 ohms resistor between pins 5 and 6 of this chip and the problem is solved.
3/11/2011 10:28:48 PM •
Samsung...
Answered
on Mar 11, 2011
When i turn on my
This is just your computer trying to give you the best resolution your monitor can handle. With the extent of modern technology being what it is, most devices will communicate information between themselves without a human being needed for most of it. This case is a perfect example. Many new monitors will "tell" the computer what their maximum resolution and refresh rate are, and the computer will automatically set your video card to use those settings. Resolution is the "1280x1024" part of the message, which refers to the number of pixels and size of area to be used on the monitor. Refresh rate is the "60Hz" part of the message, and isn't really important unless you see a flicker on your monitor or are getting into the advanced usage of a large, powerful monitor system.
The message you received was because of a miscommunication between the monitor and the computer. The monitor had no factory set value for its "Optimum Mode", so your computer was forced to ask you for input. The recommended mode should work just fine for you, so feel free to ignore that message unless it starts causing you problems, like an odd flicker in your screen or the screen not displaying your desktop properly.
3/6/2011 6:04:44 AM •
Samsung...
Answered
on Mar 06, 2011
When I open the Monitor
It sounds like you are connecting with the power on. NEVER do this!
Shut off your computer AND your monitor. When both are off, THEN connect your cable.
Then you can turn the PC and monitor on (the proven old school way is to turn on monitor first, then PC)
If nothing was damaged from connecting them "live", you should be OK.
2/10/2011 10:13:12 AM •
Samsung...
Answered
on Feb 10, 2011
I turn on my samsung
The backlight invertor seems to be defective.
Check the main power supply board for bad capacitors (visible damage ) and make sure that the invertor tubes do not light up for a moment when you power up the monitor ( in that case their probably is one or more light tube defective (burnt)) --
10/19/2010 11:26:58 PM •
Samsung...
Answered
on Oct 19, 2010
Resolution Issue
Hi
Thank you for your query
Please can you advise what graphics card you have, as i dont think you have the latest drivers for it
2/24/2010 7:49:47 PM •
Samsung...
Answered
on Feb 24, 2010
When turning on the screen/computer (windows XP)
Hold down CTRL+ALT keys and press any of the arrow keys to move to the right direction.
If its not working right click on the empty space on the screen and go to graphic properties and you will get a window. go to disply settings and select 0 under rotation.Then click apply and OK. thats it.
1/30/2010 7:38:59 AM •
Samsung...
Answered
on Jan 30, 2010
