Heating & Cooling Logo
Keith Booth Posted on Jan 05, 2018
When your small space heater doesn't work and all components and connections seem good, what can I replace before tossing it out? It's a Patton Model PPH 3185-CN
5 Related Answers
A
Anonymous
  • Posted on Jun 09, 2008
SOURCE: Patton ceiling heater Model# 2433
x48987
Anonymous
  • Posted on Dec 22, 2008
SOURCE: Patton space Heater Model # prh-5
check that the rocker switch inside isn't stuck, when the rocker swings it shuts the unit off. if it is full of dust it may be stuck. may just be bad.
Anonymous
  • 56 Answers
  • Posted on Apr 01, 2009
SOURCE: looking for a phone number to contact PATTON SPACE
Patton at l-800-528-6600 ext. 1722 (Arizona: l-800-352-0458 ext. 1722; Alaska l-800-528-0470 ext. 1722)
co7196
Ned C Cook
  • 3433 Answers
  • Posted on Aug 23, 2009
SOURCE: HF 8 Space heater with a bad switch
If you locate and procure a switch, you can more than likely replace it yourself. Get a switch of like and you can see what you have to deal with, Always disconnect the electricity before you work on it Good Luck. It really isn't a big deal to do.If you can take and send pics by e-mail I can walk you through. [email protected]
Anonymous
  • 43501 Answers
  • Posted on Jan 16, 2011
SOURCE: my Patton PUH680 space heater is not working. Do
Check out this tip that I wrote about space heater problems..
DeLonghi Space Heater does not Heat
heatman101
Have a patton space heater. Light is on when plugged in but will not start. Can you tell me how to fix?
If the light on your Patton space heater is on, but the heater will not start, there are a few things you can try to fix the issue:
  1. Check the power source: Make sure the heater is plugged into a working outlet and that the circuit breaker or fuse is not tripped.
  2. Check the thermostat: Make sure the thermostat is set to a temperature higher than the current room temperature. If the thermostat is set too low, the heater will not turn on.
  3. Check the safety features: Some space heaters have safety features, such as a tip-over switch or overheating protection, that will shut off the heater if it is not positioned properly or if it gets too hot. Check to make sure the heater is positioned correctly and not too close to anything that could cause it to overheat.
  4. Clean the heater: Over time, dust and debris can accumulate in the heater, which can cause it to malfunction. Unplug the heater and clean it thoroughly, making sure to remove any debris from the heating element.
If none of these steps resolve the issue, there may be a problem with the heater's internal components. In that case, it is best to contact the manufacturer or a qualified repair technician for further assistance.
Can I buy a heating element for this heater?
On google
Patton replace heating element Heaters Questions ... - Fixya
www.fixya.com > Forum > Tags > replace heating element > Heaters
Patton heaters replace heating element related questions and answers. Ask yourPatton ... I can't seem to find a phone number for the manufacturer to call for parts. Any help? ... Question about PQH307UM Electric Utility Heater. 1 Answer ...
Patton PQH307UM Electric Utility Heater Quartz elements ...
www.fixya.com > ... > Patton > Patton PQH307UM Electric Utility Heater
Patton PQH307UM Electric Utility Heater, quartz elements replacement related ...Element. Where can I find replacement quartz tube heating. Element Infrared ...
Patton PQH307UM Electric Utility Heater Element ... - Fixya
Patton PQH307UM Electric Utility Heater, element related issues. Get free help, solutions & advice from top Patton experts. ... The heating element is above the thermostat, and all you will see is a round disc with two wires attaching to. Ad.
Patton PUH680-U Utility Heater Replacement fan motor ...
Patton space heater power knob isn't working
First thing check see if you have power going to switch with a multimeter if you have one if there's power going in it switch need new switch probly you can us your multimeter to test switch on ohms
My Patton PUH680 space heater is not working. Do you offer replacement coils?
heatman101
1helpful
Model PT 268 heater doesn't work at all but seems to have voltage
Yes it would seem that the thermostat or the knob would be the problem...when checking for voltage you need to check for 220v across the two terminals for the heating element. You will have 120 feeding back and forth all over the place but the fan and element will only work if they have 220... so you can have voltage and it still not work...
heatman101
A small, white, plastic or ceramic part which
TRY AN APPLIANCE STORE THAT DOES REPAIRS. OR CHECK ONLINE WITH MANUFACTURER OR IF SOMEONE CARRIES PARTS FOR IT ONLINE
1helpful
1helpful
Space heater will power up, but not start,
These fans have a safey feature (sensor) that shuts the heater off if it is tipped over. It sounds like this component is not functioning correctly - may be set wrong and will not allow the heater to turn on unless you shake it to reset the sensor. If it is still under warranty return heater, if not call Patton and ask for help.
Top Patton Heating & Cooling Experts
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Paul Carew
Are you a Patton Heating and Cooling Expert? Answer questions, earn points and help others
