20 Most Recent Patton PUH9000-U Heater Questions & Answers
2answers
I purchased the Patton PUH9000 heater last year. I
My Patton PUH682 utility heater from 2011 is otherwise in excellent condition but Auto Safety Shut-Off seems to be a design problem. My overheat sensor quickly shut off the unit when surrounding air was cool. It is inside the bottom of the fan box wired between the on/off potentiometer and heating coils. I identified it by turning on the heater and watched the metal contacts separate as it tripped. On my unit, the defective overheat sensor is hardwired. Since it was otherwise useless as a heater, I decided to jerry-rig it and hope for the best. I pried back the sheet metal edge of the fan box and wrapped the sensor with electrical tape. Then I took a very small squeezable metal paper clip and lined it with electrical tape. I clamped it over the overheat sensor and it fits perfectly to prevent the metal plates from separating. Now the heater works the way it should. The cable, coils and plug don't overheat on Hot setting and it runs continuously.
11/16/2018 7:30:55 AM • Patton PUH9000-U... • Answered on Nov 16, 2018
3answers
The Caution Light ?
MILKHOUSE HEATER "CAUTION LIGHT" SOLUTION: Before I explain, let me clear this myth up: this is NOT an issue with the pendulum safety switch (some mistake that for a "mercury" switch). To begin, unplug the heater. Open it up and clean it out. I mean, buy a can of non-chlorinated brake cleaner and squirt all of the contacts good. Below the fan there is a sensor mounted on the heater element box on the bottom. That goes bad and causes it to trip. While you are there, squirt the motor bushings good with the brake cleaner and dab a drop of synthetic motor oil (just a drop) on EACH of the two motor bushings. Personally, I rewired this and bypassed all of the safety features. You can bypass that sensor without soldering or cutting any wires. All you have to do is unscrew the wires from the holder and then unscrew the tiny nuts and tiny bolts. Then bolt the together at one end (note the position) and put it back in the holder and tighten the screw to hold it in. This method fixes the issue completely as it removes the sensor from the equation. In fact, I just did that on my third milkhouse heater and it has been running solid for the last 15 minutes. Use your modified heater with caution! Let the brake cleaner dry before you energize this device!
9/15/2014 11:12:28 AM • Patton PUH9000-U... • Answered on Sep 15, 2014
I have an PATTON PUH
Here's a link to the site that has a phone number to call concerning the recall of last December.
Use it to determine if your model Patton heater was included in the recall.
http://thestir.cafemom.com/home_garden/113974/huge_walmart_heater_recall_over
There was also a recall in 1985.
2/10/2011 1:01:29 AM • Patton PUH9000-U... • Answered on Feb 10, 2011
Comes on for a sec. then goes off and on
Just answered your question. You posted it twice.
2/2/2011 8:07:25 PM • Patton PUH9000-U... • Answered on Feb 02, 2011
Comes on then goes off
Your Patton Heater may be on the Voluntary Safety Recall List. For more info call Patton Electric Co. toll- free at (800) 528-6050. You will need your Model # and Serial # before calling.
2/2/2011 8:06:35 PM • Patton PUH9000-U... • Answered on Feb 02, 2011
Heater starts but only top
This heater may have been part of a voluntary recall. For more info click on the link below. If the link doesn't work, copy and paste it into your web browser.
http://www.cpsc.gov/cpscpub/prerel/prhtml84/84025.html
1/25/2011 4:05:55 PM • Patton PUH9000-U... • Answered on Jan 25, 2011
I purchased a Patton heater
If it is the same as mine it takes a minute or two to start after you plug it in...this is a safety thing,in case it tips over...if it is tilted to much it will shut off...but will sart back up in a few minutes...
1/24/2011 6:15:18 PM • Patton PUH9000-U... • Answered on Jan 24, 2011
Puh 9000 works great for two minutes then shuts
sounds like u have a safety switch going out try to fin the one thats cutting the unit off try bypassing hem one at a time until it stops and replace it do not leave it bypassed!!!
2/26/2010 2:57:22 PM • Patton PUH9000-U... • Answered on Feb 26, 2010
I bought it new, about one week ago. I plugged it
if you blow a limit switch the fan continues to run in an attempt to cool it down,try unpluging it and letting it sit for about 30min to reset the limit switch,plug it back in if the fan continues to run with no heat replace the limit switch.
2/7/2010 1:26:44 AM • Patton PUH9000-U... • Answered on Feb 07, 2010
Space heater will power up, but not start,
These fans have a safey feature (sensor) that shuts the heater off if it is tipped over. It sounds like this component is not functioning correctly - may be set wrong and will not allow the heater to turn on unless you shake it to reset the sensor. If it is still under warranty return heater, if not call Patton and ask for help.
3/1/2009 3:01:11 PM • Patton PUH9000-U... • Answered on Mar 01, 2009
Have a patton space heater. Light is on when plugged in but will not start. Can you tell me how to fix?
If the light on your Patton space heater is on, but the heater will not start, there are a few things you can try to fix the issue:
  1. Check the power source: Make sure the heater is plugged into a working outlet and that the circuit breaker or fuse is not tripped.
  2. Check the thermostat: Make sure the thermostat is set to a temperature higher than the current room temperature. If the thermostat is set too low, the heater will not turn on.
  3. Check the safety features: Some space heaters have safety features, such as a tip-over switch or overheating protection, that will shut off the heater if it is not positioned properly or if it gets too hot. Check to make sure the heater is positioned correctly and not too close to anything that could cause it to overheat.
  4. Clean the heater: Over time, dust and debris can accumulate in the heater, which can cause it to malfunction. Unplug the heater and clean it thoroughly, making sure to remove any debris from the heating element.
If none of these steps resolve the issue, there may be a problem with the heater's internal components. In that case, it is best to contact the manufacturer or a qualified repair technician for further assistance.
2/26/2023 10:18:45 AM • Patton Heating &... • Answered on Feb 26, 2023
How can I order the manual of Patton #POH2420?
Unfortunately you can't. These are made overseas and badged to whomever sells them. The manual for the 9000 model is available, but not yours. This may be the closest? http://www.useandcaremanuals.com/pdf/WOFH7167.pdf https://www.google.com/search?q=Patton+POH2420+manual ..
11/5/2021 2:27:33 AM • Patton Heating &... • Answered on Nov 05, 2021
What website will have the Patton AccuTemp floor heater Model POH2420?
I would try the manufacturers web site.
11/2/2021 6:37:37 PM • Patton Heating &... • Answered on Nov 02, 2021
Heating & Cooling Logo
Popular Tags
19 questions posted
Top Patton Heating & Cooling Experts
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Paul Carew
Are you a Patton Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Patton Heating & Cooling
Most Popular Question
purchased patton puh9000 heater last
  • Heating & Cooling
