Hi how are you
indiset uu18f1dx red light blinking ??
whats problem
My guess would be yellow?
https://www.repairclinic.com/RepairHelp/Freezer-Repair-Help
This site may help or your users manual should have detail on that.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
SOURCE: Alarm
the alarm is there to warn you that the freezers not up to set tempature.. The reason as I see what you wrote would be a stuck or burnt out auto defrost timer motor. or the units got a leak in the refrigerant line??? good luck
SOURCE: Proline FS 707 Upright freezer -problem
Check that the air vent is free from anything blocking it at it maybe over heating.
Thanks J
SOURCE: Philips Freezer
I used to sell freezers.the green light tells you the mains is on and the freezer should work.The red light is to inform you the freezer is not low enough temperature,and the orange light is a fast freeze light to over ride the thermostat for use when introducing fresh food.It should not be used for prolonged periods as it may burn out the compressor although in your case you already have a problem and should seek advice or buy another freezer.If you get a cheap freezer thermometer it should confirm what I am saying.
