I'm getting the message that my waste ink absorber is nearly full. How do i service this??
Hi. As you have not mentioned the make and model of the printer, I am giving here the procedure to reset waste ink counter applicable to most printers. Hope it helps.
Canon Pixma iP1200, iP1600, iP2200 Resetter
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
If you have a different printer model, then please tell me and I will research that for you. Thanks.
Does this work for the Canon Printer Model MP190 please
reply to email: [email protected]
How about my canon mx347...it also says" The ink absorber is almost full. Contact the customer service provider".....Please help me to reset ....I dont find any solutions for this kind of model...
SOURCE: Canon pixma MP 130 waste ink absorber
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
SOURCE: waste ink absorber near full
try this website
http://www.polyphoto.com/tutorials/PrintHeadCleaning/CanonCleaningAndReset.html
Let me know if that works
Mitch
P.S. Don't forget to leave feedback
SOURCE: how to reset waste ink absorber full ip3300 warning?
I have the same problem, but Jet Tec waste inks. When I first replaced black (pgi 5bk)-don't forget to place the small chip from the original cartridge to replacement; it worked fine. But now, it has a lot of problems because this **** printer from canon only want original inks (and the original are tooooooooo expensive). I'll never bought anything else from canon.
SOURCE: waste ink absorber full--where do I get it serviced? or, can I do anything?
in some canon printers, you can look down into the printer, carefully remove the sponge rubber "Absorbrer" wash it under a running tap and very carefully replace it, making sure it is fitting back exactly where it was. I did this twice and then reset the counter using the code above. If you reset too many times without getting rid of the ink, the ink can leak out of the printer. I was quoted $AU65 by a Canon dealer to do this on a $AU99 printer. I bought the new printer same model, with 4 new ink Carts, that sell for $AU22.95 each, and pulled the old one to bits to see what does what!
SOURCE: I have the message: Waste ink absorber is full.
If pineworks solution does not work, you may want to clean the print heads.
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
1. Clean your ip3000 print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
Time necessary 45-50 minutes
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your ip3000 in new condition.
Happy Printing .
Eight flashes: Waste ink absorber almost full
The printer has a built-in waste ink absorber for the ink used during Print Head cleaning. Eight flashes indicates that the waste ink absorber is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink absorber becomes completely full, contact a Canon service representative.
Important
Canon recommends that you call for service as soon as this error occurs. Once the waste ink absorber becomes completely full, printing will no longer be possible
