Health & Beauty Logo
a
annette h Posted on Oct 24, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a GC# Pride product JB3131114056c30 it is showing PMM1 Brake Error
wcdoc1953
Level 2:
  • Expert 280 Answers
  • Posted on Oct 25, 2017
wcdoc1953
Expert
Level 2:
Answers
280
Questions
0
Helped
129828
Points
552
The error code suggests a problem with the power module motor 1 output to the brake or a problem with the motor 1 brake. You can swap the motor leads to see whether the problem is in the module or brake.
I have a Quantum Q6 Edge 3 with Q-Logic 3. When I connect the Quantum handheld programmer 1313-3309 I get a "#208 Supervision Error". How can I get past this to program the controller?
error code 208. Page 108
http://javafoundry.com/home/Q-Logic_Technical_Manual.pdf
208 Brake 1 Overload: current too high
I can't find anything on 'Supervision Error'.
https://www.google.com/search?q=Quantum+Q6+Edge+3%2C+208+Supervision+Error
you could contact them direct
Pride Mobility Products Corporation 182 Susquehanna Avenue Exeter, PA 18643-2694 USA
Pride Mobility Products Company 380 Vansickle Road Unit 350 St. Catharines, Ontario L2R 6P7
Canada Pride Mobility Products Ltd. 32 Wedgwood Road Bicester, Oxon OX26 4UL UK
Pride Mobility Products Australia Pty. Ltd. 21 Healey Road Dandenong, 3175 Victoria, Australia
Pride Mobility Products Italia S.r.l. Via del Progresso - ang. Via del Lavoro Loc. Prato della Corte 00065-Fiano Romano (RM)
Pride Mobility Products Europe B.V. Castricummer Werf 26 1901 RW Castricum The Netherlands
2answers
Controller flashes 9 times what does that mean
Basic Troubleshooting Instructions - Pride Mobility Products
www.pridemobility.com > Resource Center
Pride MobilityINFINFB2468 Jazzy 614/Jazzy 614HD with Dynamic Controller Troubleshooting ... LiftChairs. INFINFB2061 Basic Troubleshooting Instructions: Lift Chairs ...
Pride Mobility Products Corp. - Product Owners Manuals ...
Pride MobilityHelp Me Choose · Where to Buy · Request to Be Contacted · View all Models. Pride Mobility Scooters ... Power Chair Consumer Safety Guide .... Version / Date. Flash. C 01/04. Pride LX Series. C 05/08. Z-11. B 07/04. Manual Wheelchair ... Travel Scooter Throttle Control Lever Operation Product Insert ... Victory 9/Victory 10 ...
Troubleshooting / Repairs Mobility Scooter, Power ...
1helpful
Scooter is saying error code 8 which is motor does anyone know what this could be please?
Pride Mobility Products Victory 9 Scooter 4 Wheel Error code
www.fixya.com > ... > Pride Mobility Products Victory 9 Scooter 4 Wheel
Pride Mobility Products Victory 9 Scooter 4 Wheel, error code related issues. ... Question about Thermometer Mobility Scooters ... error code is 8 Error code 8 means an internal controller error or problem and requires replacement of the controller. ... Theysay there is no listing for code 9 I have replaced the batteries,checked .
Basic Troubleshooting Instructions - Pride Mobility Productswww.pridemobility.com > Resource CenterPride MobilityScooters. INFINFB2040 Sonic Troubleshooting ... Chargers. INFINFB2586 Charger Indicator Codes ... Disclosure Statement Pursuant to Cal. Civ. Code 1714.43(a)[PDF]Legend Owner's Manual - Pride Mobility Products
My Pride GOGO scooter is stuck in drive and wont go into freewheel?
The park brake has got stuck, the brake needs to come off and be stripped down and cleaned, this will sort it.
Flash code is 5 flashes pause then 5 flashes what does 5 flashes mran
What controller??? For a Dynamic Controller it is an error code 5: left park brake fault. Check the brake connections.
1helpful
Hi, I have a jet 3 ultra chair . I have just put new batteries on and can still only do about 4 miles from a full charge, any ideas, Many thanks Rolfe
Rolfe could be a couple of things check the brushes in each motor for excess wear and check to see if the motors are getting overly warm after driving for awhile if they are then you could have a brake problem on one or both of the motors. If your brushes are less than 1/8" long then they need replacing and you can have a provider order some from Pride for you or have them service the motors for you. If it is the brake then it will have to be replaced by a tech who knows what to do if you can get the brake from Pride. Now I'm not suggesting this or recommending this because of safety and liability issues but you could remove the brake from the rear of the motor that is getting hot (if it is) leaving the wiring connected and hang the brake in the rear of the chair so it won't break the wiring and drive the chair to see if that makes a difference. If you remove the brake and wiring then the chair won't move at all because the controller is looking for the brake when you turn on your chair if the wiring is disconnected you will get a fault error and the chair won't move. Also have someone load test your new batteries just because"new" doesn't mean good and a weak battery will reduce distance driven. Hope this helps
1helpful
My Pride Hurricane PMV will not go forward or backwards when I engage the trottle all I get is a click but it will not move. The battery meter shows fully charged.
Make sure that the manual brake release/freewheel lever is in the DRIVE position. The click indicates the brakes are being released but the motors are not kicking in. I hope this helps- good luck!
Pride mobility scooter wont move you can hear the brake click off when the throttle is pushed but the motor does not start
hi, that noise could be a relay clicking off inside the motor controller because the brake on the motor has failed to release,
It quite a common problem and the only way to be 100% sure is try a replacement brake unit.
Regards
GeWiz.
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
