20 Most Recent Pride Mobility Products New Pride Mobility Jet 3 Ultra Power Wheel Chair Questions & Answers
gilly your controller still thinks you are charging the chair. This error is a charger inhibit error which means that when you have the charger plugged in you can't drive the chair. If your charger is not plugged into the chair then you have a problem that needs to looked at by your provider where you got the chair or by a tech Sorry I don't have a quick fix Hope this helps you
Pride Mobility... | Answered on Dec 09, 2016
We have no way to look up repair facilities from here. We are in California USA
Pride Mobility... | Answered on Jun 24, 2016
The fix for this fault is to replace the chip in the VSI controller. This happens when you consistently drive the power chair with weak or low voltage batteries.
Pride Mobility... | Answered on Oct 20, 2015
If the joystick turns completely off when you try to drive it means the batteries instantly are dropping voltage below the operating capabilities. I have also seen bad connections in the battery wiring harness cause the same thing.
Pride Mobility... | Answered on Oct 13, 2014
Do they flash in series? Like ten flashes then a pause then ten flashes?
Pride Mobility... | Answered on Aug 21, 2014
Check and see if the charger is still plugged in when you have this fault. Usually a 7 light flash is a controller fault. Sometimes it will also mean you have one or both motors disengaged. If the charger is not plugged in when you have this fault then try and push the chair. If it moves freely then you need to engage the motors. If you have to engage the motors you will have to power down the chair and power it back up to clear the fault. If this does not work you will need to contact a technician to troubleshoot the root cause.
Pride Mobility... | Answered on Jun 05, 2014
Wbritt You can call Pride Mobility @ 1-800-800-8586 select parts and order part # FRMASMB3772 make sure to ask if that is the correct part # for the rear caster assembly Hope this helps
If this is a new power chair, I would contact the business that sold it to you. Should be under warranty. It could be just a loose plug of some sort but you would have to remove the seat and the red shroud cover to get to the plugs
Pride Mobility... | Answered on Apr 08, 2014
Contact the manufacturer of the lift for the brackets. Depending on what type of lift it is, you will either order the bracket from them or from a Pride Mobility Dealer or the lift dealer
ahh tape them up please,they are yoyr a part of your controller wires for the motors,ty
Pride Mobility... | Answered on Jan 19, 2014
Code 8: Controller problem. Also, check to see if your gearbox levers are engaged - if you can roll the chair by hand the gearbox is not engaging the motors.
Pride Mobility... | Answered on Jun 05, 2013
Pride Mobility Products New Pride Mobility Jet 3 Ultra Power Wheel Chair Logo
86 questions posted
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Will
Level 1 Expert
Marvin
Marvin
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Pride Mobility Products Health & Beauty
Most Popular Question
remove quick disconnect battery
  • Health & Beauty
