20 Most Recent Pride Celebrity X 3-Wheel Electric Scooter Questions & Answers
The speed pot needs to be checked for a loose connection. If it looks good then the pot needs replaced.
Pride Celebrity... | Answered on Sep 03, 2017
Hi remove key put freewheel lever into drive & replace key .turn on...,... good luck.,
Pride Celebrity... | Answered on Aug 21, 2017
It's the red battery cover under the seat. Carefully lift and remove the seat and you'll find that the shroud is simply attached with velcro
Pride Celebrity... | Answered on Aug 02, 2016
Hidden under the floor mat and hatch, you'll find two high amp fuses that Pride say don't exist! - they do. Be careful with the rubber mat lugs they deform and are tricky to reseat.
the fuses are standard car fuses. It's busually the red 10 Amp fuse that's blown.
the cause of the problem may possibly be the three pin XLR cable/ plug.
Pride Celebrity... | Answered on Jun 02, 2016
Your wigwag pot sounds faulty you can very often buy a good used one on eBay
Try the Charging circuit fuses hidden under the mat and floor hatch.
Is the charger OK?
Are the batteries coming to the end of their life?
If the battery wont charge the item will need a service engineer to test it. I am not sure of the particular model but there is a possibility that either the charger itself is at fault OR the charging circuit has either a diode or capacitor damaged.
If the charger plugs into a 240v socket in the house have the charger checked to show voltage is being output by it.
If it is then how old is the battery on the scooter? does it need replacing? have a voltage test done.
If both the battery and wall charger if there is one is OK then I would say another part of the vehicles circuitry made be at fault and suggest you have it looked at. .
Pride Celebrity... | Answered on May 15, 2016
Hi, any bleeping, flashing lights , double check the freewheel lever,
1. Any clicking from the rear .
Please keep me updated.
Regards
Pride Celebrity... | Answered on Jan 22, 2016
hi Eddie , three legs, the two outside legs will measure around 5K resistance , the centre one is the wiper..
Regards
Rob
Pride Celebrity... | Answered on Nov 23, 2015
The speed pot is the knob you use to go from turtle to rabbit. You can go to the website of the manufacturer to get a service manual
Pride Celebrity... | Answered on Nov 21, 2015
Possible Control System Trip
A control system trip is indicated. Make sure that all connections are secure.
Pride Celebrity... | Answered on Jun 16, 2015
How many flashes on green light. Count them and you should find in the trouble shooting section of your user manual what the problem is. Most cases you can sort yourself.
Download the service manual from Pride's website for detailed instructions on what the flashes mean and how to fix it.
Pride Celebrity... | Answered on Feb 24, 2015
If the motor is overheating, it is drawing far more current out of
the batteries than it is supposed to. Assuming it is 2 x 13v x 33ah
batteries, these are good for about 2 to 3 years on my scooter and 'wheelchair. AGM (absorbent glass mat) lead acid batteries do deteriorate over time due to battery chemistry.
Although the batteries may appear to take a charge
and the voltage 12.6volt x 2 = 25.2 volts nominal, with no load
on them, the motor controller takes a whack of current to get you going.
I have an digital voltmeter/ammeter installed on my Pride XL scooter and I was amazed how much current the motor/motor controller takes from the batteries. 50 to 80amps on startup.
If the battery voltage drops due to the age of the batteries, as the
energy is being used up from them, the current required by the
motor for rotation has to go up, and that will cause overheating of the controller and the motor. It is Ohms law plain and simple
the less voltage available-the more current required to do the
work and current creates the heating effect.
I replace my batteries every two years. Can't take a chance on
being stuck with discharged batteries.
Pride Celebrity... | Answered on Feb 21, 2015
hi, is this a built in charger ?
where you insert a mains plug ?
Regards
Pride Celebrity... | Answered on Jan 12, 2013
Regards
Pride Celebrity... | Answered on Jan 11, 2013
Pride Celebrity X 3-Wheel Electric Scooter  Logo
Popular Tags
32 questions posted
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Pride Health & Beauty
Most Popular Question
battery fully charged but green light
  • Health & Beauty
