20 Most Recent Pride Jazzy 600 JAZZY 600 Questions & Answers
Hi ring this number they might b able to help with youre problem ,,1-800-800-8586.... Cheers
Pride Jazzy 600... | Answered on Sep 13, 2016
You don't you, replace joystick. However, should you take the joystick apart you may have many hours of intense frustration awaiting you.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Pride Jazzy 600... | Answered on Apr 09, 2016
You would need to remove both covers top and bottom of the console holding the throttle pot. Typically, there are 4 or six screws holding the covers. The throttle pot is attached with 2 screws and has 1 electrical plug. The throttle lever on the end of the throttle pot shaft usually is held on with 2 Allen wrench set screws.
Before replacing the part it can be tested using a digital voltmeter.(procedure is described elsewhere).
Obtain the correct replacement part by searching by Model and serial number and part description. The manufacturer website is a good starting point for parts
Pride Jazzy 600... | Answered on Jan 20, 2016
PDF]INFINFB2043_Jazzy_600-600XL_Troubleshooting_Rev B ...
www.pridemobility.com/download.php?...Jazzy_600-600...
Pride MobilityWhat if the systems on my Jazzy 600/Jazzy 600XL seem to be "dead" (controller does not ... Each controller will flash a code via the battery ... 7. Joystick error. Contact your authorized Pride Provider. Four yellow LEDs ... This is indicated by the VR2/VSI speed ... flash in a numbered sequence followed by a 2-second pause
Pride Jazzy 600... | Answered on Jan 18, 2016
hi,
Joystick code 8 == Controller error
Three red LEDs
Four yellow LEDs
One green LED.
Please confirm this, if you're UK based , i can repair these units...
regards
Rob
www.gewizrepairs.co.uk
Pride Jazzy 600... | Answered on Jul 10, 2015
Try squirting some wd-40 down into the button.
Pride Health &... | Answered on Mar 12, 2019
Rob Hill Feb 20, 2018
hi, okay mainly one of two reasons , the wigwag is worn reverse side of the pot or the controller has a fault, now the wig wag, when going into reverse try gently pushing the lever up and then down while holding it in reverse , be careful the scooter could jolt back, so turn the speed down. if the scooter does in fact response to that then a new throttle pot is required. I do controller testing for free , you only pay the return postage.. Regards
GewizRepairs
Pride Health &... | Answered on Mar 06, 2019
Pride Jazzy 600 JAZZY 600 Logo
5 questions posted
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Pride Health & Beauty
Most Popular Question
replace throttle potentiometer s
  • Health & Beauty
