20 Most Recent
Pride Jazzy 1103 Ultra Standard Power Chair Questions & Answers
CHAIR IS CHARGED UP BUT
ajnss I need more information. can you turn the power on at the joystick? are you getting all the lights for battery level lit? are any of the lights blinking on the joystick? do you hear a clicking noise when you try to move the chair? Give me as much info as you can thanks
How do i obtain the electrical diagram for a jazzy
Hi
The Jazzy 1103 PDF document contains a lot of the electrical diagrams I've got it if you send your email address i'll send it 2 u. put the word at in place of the @ that will stop you getting sent spam
Tony
Lights on hand control flash off and on and chair will not operat
There is a series of diagnostic flash codes associated with the controller. The diagnosis depends on which color and how many lights are flashing. If you post the combination, I can help you. Or you can download the Basic Operation Instructions of the Pilot Controller from the Pride website. The codes are listed on page two on the troubleshooting instructions.
Will not operate.
hello,i love being of help,im disabled myself.if i help,it would be nice for you to say thanx,but i am not here for prsonal gain,but because i care. Now onto your answer you require,i recently visited shoprider homepage & downloaded a PDF File of a troubleshooter for my scooter also in the troubleshooter was the troubleshooter for an electric wheelchair.it had so many useful tips & depending on what the joystick displayed,that was your guide to solving your problem.you can also print off the troubleshooter for future,try it with yours.& if your not up on computer skills just ask someone in your family.i hope this helped you Colin.
Plug charger in and will not charge the fan on the
David Are you leaving the power on while you are charging the Chair? If you are try charging with power off at the joystick. The manufacturers of all power batteries do not recommend charging with automotive chargers. I would try to locate a friend or neighbor that also has a chair or scooter and borrowing their charger for a few hours to see if it will charge your chair. If not contact your provider and borrow a charger from them. If the different charger works then yours is bad. You shoud be able to order a charger through your provider or by calling Pride Mobility @ 1-800-800-8586 Hope this helps you PS I didn't say you couldn't use the "other" charger. But I wouldn't want you to think I approved of it
We had the batteries replaced on 3/30/16 and now the red light is constant and when we charge it .. nothing changes... it barely moves and I do not believe it charges... the batteries are new
They have complicated control computers and are very touchy concerning the amount of voltage in various parts of the system, such as how much current the motor is drawing. Sometimes transmissions go dry of oil causing the gears to bind, throttles develop oxidation on the contacts, terminals get corroded. I had to bypass my original unreliable controller completely with a DC variable speed board from China. Test your batteries by connecting each to their own standard car charger. Get the back wheels off the ground with blocks and test run the motor while connected to the chargers. And test each battery with something powerful that can determine its strength, not just a small test light.The chargers are reliable, but the control brain (module) maybe not. Make sure your batteries are not dry, make sure fuse is OK, terminals are clean, charging system must be unplugged to run, test test test. Make sure the speed limiter is tried in various positions, parking brake or lock is in correct position.
How do you adjust the front springs s0o that the rod wont bnd and break?
www.usatechguide.org/itemreview.php?itemid=929
13 posts - 11 authors
Anti-Tip Wheels 6&8221; solid; front-mounted • Suspension Limited. ... get either aPride Jazzy, or a Jet 7, you'll be very happy, as long as you can afford a lift ... If youdont, the charge keeps going down, and will not ever recharge back to the ... These products need to be charged about 8 hours a day after usage, so its better ...
