20 Most Recent Pride Jazzy Select 6 Indoor Power Wheelchair Questions & Answers
No. You can lock the controller electrically. You need to check the operators manual for the procedure for the model of controller you have.
Pride Jazzy... | Answered on Sep 03, 2017
I tried to charge my jazzy. The charge light (red) remained on for several hours. Finally I moved the wire slightly the charge light turned green than faded to red. What is my problem? Your solution would be greatly appreciated.
Pride Jazzy... | Answered on Aug 23, 2016
You have two good batteries in the green side, the red light means that one or both batteries are not fully charging. Try that set on the other side to confirm. Make sure the batteries and charger connections are clean.
Hope this helps.
Pride Jazzy... | Answered on Aug 20, 2016
'just search "mobile scooters", then go to the" pride "web site. You can download your manual, etcl or print it from there.
Pride Jazzy... | Answered on May 04, 2016
This is the procedure to unlock the controller on a Pride Jazzy:
Locking/Unlocking the VSI
The VSI has a feature that enables you to
lock your power chair to prevent unauthorized use.
To lock the VSI:
1. With the VSI switched on, press and hold the on/off key. After 1 second, the VSI should beep.
2. Release the on/off key.
3. Push the joystick to the full forward position until the VSI beeps.
4. Pull the joystick to the full rearward position until the VSI beeps.
5. Release the joystick. There should be a long beep.
6. The VSI is now locked.
To unlock the VSI:
1. Press the on/off key and power on the VSI. The maximum speed/profile indicator should ripple up and down.
2. Push the joystick to the full forward position until the VSI beeps.
3. Pull the joystick to the full rearward position until the VSI beeps.
4. Release the joystick. There should be a long beep.
5. The VSI is now unlocked.
NOTE: If the above procedure fails to either lock or unlock the VSI, contact your authorized Pride Provider.
Pride Jazzy... | Answered on Mar 21, 2016
Check to see if both motors are engaged. If not the problem, most likely controller has a short in the circuit board.
Pride Jazzy... | Answered on Feb 29, 2016
Yes. Change the potentiometer behind the throttle lever. It's probably 10 ohms. Try a lower resistance pot. It will run the battery down quicker though.
Pride Jazzy... | Answered on Jan 17, 2016
My tires squeak how can i fix the problem and what ... - Fixya
www.fixya.com > ... > Pride > Jazzy Select 6 Indoor Power Wheelchair
Apr 14, 2012 - my tires squeak how can i fix the problem and what can i use - PrideJazzy ... Question about Pride Jazzy Select 6 Indoor Power Wheelchair ... I have a mpv 5 hoveround wheel chair and I now have a flat on the front left tire.
[PDF]Jazzy Select Series Owners Manual - Pride Mobility Products
www.pridemobility.com/...jazzy/us_select_series_om.pdf
Pride MobilityJazzy Select 6 with Power Seat. JAZZY. SELECT SERIES. Including Models: Jazzy Select, Jazzy Select 6, and .... Battery charger for indoor use only. .... Take wide swings with your power chair's front wheels around any tight corners. ... desired, allow it to come to a complete stop by releasing the joystick, then push the ...
[PDF]Jazzy Select Series - Pride Mobility Products
Pride Jazzy... | Answered on Dec 28, 2015
I have repaired thousands of jazzys elec wheelchairs and never have seen a fire or melt down
Pride Jazzy... | Answered on Nov 24, 2015
There should be a place to plug the charger in on the front of the joystick. It is a round three pin connector
Pride Jazzy... | Answered on Aug 08, 2015
i have a jazzy select and can i put larger tires on to improve ground clearence?
Pride Jazzy... | Answered on Jul 06, 2015
This is usually one of two things. You will need to pry the on/off button away from the joystick for inspection. Use a utility knife to get under the edge and pry it off.
The back of the rubber button is coated with a material that conducts electricity so that when you press it, it makes contact with the surface under it which is also conductive.
1. For older chairs that get a lot of on/off use, this metalic coating on the back of the switch can wear away and not make good contact with the base. Examine the back of the on/off button for wear; you will see the rubber under the metalic coating if it is worn. Pressing around the edges of the button might work to get it on and off, or pressing harder. Otherwise, you need to paint on a new coating. Here is a site that sells that product.
http://www.newark.com/chemtronics/cw2605/conductive-chemical-coating-3g/dp/00Z1875?mckv=sskjVGufT'pcrid'57087234861'plid'&CMP=KNC-GPLA
2. If you have spilled something on the joystick that has fouled the connection here, it will have a hard time making contact to turn on and off. Clean with alcohol and cotton swabs, let dry and see if that does the trick.
Pride Jazzy... | Answered on Feb 26, 2015
The controller stops the batteries when the voltage gets too low to prevent damage to the batteries and the elecrtronic components.
Pride Jazzy... | Answered on Feb 24, 2015
You have to disconnect the charger in order for the chair to move. It automatically removes power from the controller while the batteries charge.
A light touch on the joystick is first. If it remains difficult then have the joystick reprogrammed. Only a dealer is set up to reprogram a joy stick.
You may need to lubricate the wheels and where they pivot on the frame, otherwise that's the way they operate normally.
If your charger has a red and a green led on it when the green led lights the battery is charged. If you use it a lot during the day it may take 8 to 10 hrs or more to fully charge the batteries
Pride Jazzy Select 6 Indoor Power Wheelchair Logo
198 questions posted
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Pride Health & Beauty
Most Popular Question
turn jazzy select lift chair
  • Health & Beauty
