SOURCE: E1 Error
If your sewing machine show's the E1 Error, then you have to open your sewing machine and replace the fuse.(you have to open the right Cover on Front where the Display is placed, because there is the circuit board placed!) There are 3 Fuses in the Sewing machine and they are placed at the printed circuit board. It should be the Fuse in the middle. (not those with the wire in it!) It's not easy at all to open the machine, the best thing you can do (if you have a Digicam) take some Pictures of the wiring so it will be much easier to put it back together. I'm NOT an Expert; but a passionate hobbyist. ;) If you are too; just save yourself further trouble with the helpdesk, and fix it yourself. I hope this post could help you!
SOURCE: Stop for Safety Purposes ?
I have had this happen to me many times. It really does feel as though the problem is in the bobbin, but it's not. After much aggrivation I took it into the repair shop and found out the thred was comming unhooked on the top not in the bobbin. It still happens all the time but I know what it is now so I just rethred the top.
SOURCE: Janome Compulock Serger computer needs to be reset
"You hold down on the needle down button while turning the machine on.. "
That is correct, then release it immediately power is on, THEN...
press the "C" button to reset to factory configuration.
If you need more help with this contact me through the Contact Us page at www.bargainbox.com.au and I shall send you the relevant page from the service manual.
Don't forget to specify what you request is about...we do get quite a few for a variety of things !
SOURCE: WHERE CAN I FIND MANUALS FOR JANOME SEWING
Look HERE for Janome User Manuals, enter model number in the search box (top left). Janome Service & Repair Manuals HERE just request your model.
SOURCE: I want and need a copy of the owners manual Janome Compulock
http://content.janome.com/documents/File/ManualFile/Inst%20book%20CompuLock.pdf
