20 Most Recent Janome Memory Craft 3000 Questions & Answers
2answers
Lost Manual
Here is the Manual
11/8/2022 9:51:33 PM • Janome Memory... • Answered on Nov 08, 2022
Janome MC 3000 shank height
The Janome Memory Craft 3000 uses a low shank snap-on presser foot with a presser foot holder for most of its standard presser feet. See page 17 (page 19 of the PDF) of the User Manual available from Janome on the retired machine support page: https://www.janome.com/support/retired-machine-manuals/ . The current link to the manual is https://www.janome.com/siteassets/support/manuals/retired/computer/inst-book-mc3000.pdf . For specific presser feet that originally came with the machine, see page 3 of the manual (page 5 of the PDF). You can get presser feet that are known to be compatible at most sewing machine supply vendors, including https://www.sewingpartsonline.com/janome-memory-craft-3000-sewing-machine-parts.aspx?filter.ptype_gmcfeed_1=%20Presser%20Feet&index=39 or https://www.sewingmachinesplus.com/janome-mc3000-parts-accessories.php . A few presser feet have their own shank and require you to take off the holder. I hope this helps. Cindy Wells
4/15/2022 9:53:51 PM • Janome Memory... • Answered on Apr 15, 2022
FAT error on format
FAT error fixed! Formatted using my Canon SLR camera. I would like to credit whomever it was that suggested using the Camera to check if the card was working for the thought. I had spent many hours attempting to format and reformat my cards using Windows 10 64bit Pro machine. They would work perfectly fine on the computer but would fail on my MC 10001 every time. The MC also failed when trying to format on the sewing machine. Then I stumbled across this thread. I can only guess that the age of technology has become incompatible with the way my computer formats the card. Once I formatted using the camera, everything magically works. Of course, I needed to reformat using the MC machine; but, that was a breeze. I hope this helps someone!
9/20/2020 10:01:58 AM • Janome Memory... • Answered on Sep 20, 2020
How to lower feed dog on janome memory craft 3500
There's a slider on the back of the machine. Down low, behind the bobbin area. If you put your hand back there you will feel it.
11/6/2018 10:59:49 AM • Janome Memory... • Answered on Nov 06, 2018
The hand wheel is not moving the needle at all
Check the hand wheel. There should be a smaller wheeel in the center of the hand wheel. Make sure it is locked in(turn center wheel clockwise or could be counter clockwise til snug)
10/2/2018 1:44:52 PM • Janome Memory... • Answered on Oct 02, 2018
I think there might be something wrong with the foot control of my Janome Memory Craft 3000, since the machine wont go when I press the pedal with my foot, but if I jiggle the connection where the cor
Most likely, a replacement foot control would be the best option. I found one on Amazon for less than $60. Although, perhaps it is the actual plug in the machine that is sloppy--something that could probably repaired by the local sewing machine repair shop. FWIW, purchasing a new replacement machine will be more expensive. However, if you are hankering for a machine with more options, etc., then maybe not. IMHO, the older machines are usually better. It would be wise to check out the price of current machines on the market before making a decision. Janome Heritage The Memory Craft 3000
8/11/2017 3:53:49 PM • Janome Memory... • Answered on Aug 11, 2017
The needle is not in time with the bobbin on my Janome Memory craft 3000. What can I do?
Search for sewing machine timing or take it for service.
3/1/2017 6:32:53 AM • Janome Memory... • Answered on Mar 01, 2017
Can't clear stich selection
Have you tried turning off the machine and unplugging it for a few minutes so the memory can be cleared? ...
2/7/2016 5:55:03 PM • Janome Memory... • Answered on Feb 07, 2016
How do I set bobbin tension?
Generally bobbin tension is the last thing to try to adjust on your machine. Most sewists adjust the bobbin tension ONLY if they are using very lightweight or very heavyweight thread in the bobbin. Most sewists will advise to make all possible adjustments to the top tension before tackling the bobbin tension to resolve issues. Try searching YouTube videos or this may be helpful: Bobbin Tension How and Why Tension is Adjusted Understanding Bobbin Tension Setting the Bobbin Tension on your sewing machine Liz Kettle adjusting your bobbin case tension 1 wmv How to fix Tension Don Panic ....
9/27/2015 5:52:40 PM • Janome Memory... • Answered on Sep 27, 2015
Where can I find someone to service a New Home sewing machine in Inverness?
Quilt Creations 98 Church Street, Inverness 01463 719369 Janome Agents so can help you with a New Home
4/19/2015 10:42:52 PM • Janome Memory... • Answered on Apr 19, 2015
2answers
Memory 3000 makes occasional screeching noise
Take in in for a Maintenance. There are many areas the may need a drop of oil, or adjustment. You don't want to do it.
3/26/2015 1:40:39 AM • Janome Memory... • Answered on Mar 26, 2015
Tighten the pressure foot
We have a sewing machine that was manufactured by Janome. It is a New Home Deluxe Model. It has very little travel on the pressure foot itself versus other sewing machines. I have learned just by using this machine.... If you need to get the foot up high...all you have to do is reach through and grab the pressure foot and while picking it up(not the lever but the foot itself) turn it clockwise just a touch and it will stay up plenty far enough to get larger or thicker material under it to sew. I hope this helps. Thanks and remember "Be Easy!" Neighborsboy If you need further help, reach me via phone at https://www.6ya.com/expert/greg_012fb269876eb4b0
9/21/2014 4:08:36 AM • Janome Memory... • Answered on Sep 21, 2014
My memory craft 300 will not button hole properly.It will not go backwards after it has done its first lot of stitching
Check your manual you might have to push the reverse button a lot of machines you have to do the button hole manually.
8/29/2014 5:35:39 AM • Janome Memory... • Answered on Aug 29, 2014
2answers
My machine makes a terrible squealing noise when I sew a little faster what could be the cause of that?
Does the machine have a belt? Check your owners manual for replacement.
5/15/2014 12:00:56 AM • Janome Memory... • Answered on May 15, 2014
My janome memory craft 300e is telling me to check the needle, is something stuck in the machine or my fabric is to thick. None of htese apply. I have changed the needl and took the bobin out and cl
it's possible that the computer part of the sewing machine is going out or the computer could have a short in itit needs to be serviced
4/20/2014 2:45:53 AM • Janome Memory... • Answered on Apr 20, 2014
0answers
No display
Be the first to answer 3/19/2014 7:30:00 AM • Janome Memory... • Posted on Mar 19, 2014Be the first to answer
0answers
0answers
Sewing Machines Logo
138 questions posted
Top Janome Sewing Machines Experts
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Janome Sewing Machines
Most Popular Question
machine makes terrible squealing noise
  • Sewing Machines
