Maax elite premium 80 spa . 2004 model year
SOURCE: main jet sizes
The sizes are stamped on the Jet it self. For the Honda Shadow it is a 185. Not sure for the steed.
SOURCE: 50 amp GFCI breaker trips after spa runs for 45
More than likely, it's the element. They begin to 'leak' small current as they get old and this will trip the GFCI
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: Maax bathtub Palace model Error code C01 jets don't turn on.
first of all check the circuit breakers to be sure one or both aren't kicked. be sure to turn the breaker all the way off and then fully on as a tripped breaker is in a halfway off position. if that doesnt fix your problem remove the access panel to the mechanical space in your tub. there are generally one or two reset buttons in there which can also kick off and need to be reset.
SOURCE: Hi, We purchased a Maax 10 jet Whirlpool tub
http://www.maax.com/Upload/guides/fr/000_10050073_0305.pdf.......this should take care of what you need. If you have any questions just ask.
Thx
Ken
SOURCE: one side of jets not working + pump cuts off too
JET MAY BE PLUGGED . SNAKE IT WITH A CLOTHS HANGER.OR GARDEN HOSE. THIS MAY BE YOUR PROBLEM WITH THE MOTOR SHUTTING OFF. ITS CALLED DEAD HEADING .THIS MAKES THE MOTOR WORK REAL HARD= HIGH AMPS=HEAT+EVENTUAL MOTOR FAILURE OH AND HIGH POWER BILLS AS A ADDED BONUS. CHECK POWER CORD THESE UNITS MUST BE CLOSE TO THE POWER SUPPLY
