20 Most Recent Maax Calla 6042 Bathtub - 101058-000 Questions & Answers
If you are filling the tub full enough and the pumps are still not working, the level sensor is bad and needs to be replaced. One can be ordered directly from Maax out of Canada
Maax Calla 6042... | Answered on May 15, 2016
see if ther is another panel arond tub,there may be another breaker,try resetting breakers turn off the back on,see if this works
Maax Calla 6042... | Answered on Feb 24, 2015
Bath tub heaters will only maintain the water temperature in the bath. They will only heat the water approximately 1-2 degrees an hour.
Whatever water temperature you start with is what you will be able to maintain.
There is a red indicator light on the front of each heater indicating whether or not there is power to the unit when the tub is full of water and the water pump is turned on.
If there is a red light on then it has power to it and is working.
This heater will never feel warm to the touch.
There are three different styles of Bath Heaters available.
  • Tee Heater - installs on the discharge fitting on the pump
  • In-line Pressure - installs anywhere in the plumbing line before any jet.
  • In-line Vacuum Heater - installs before the suction of the pump
If the heater you purchased is installed in the wrong place it will not operate.
Rod
US Parts Center
Maax Calla 6042... | Answered on May 01, 2014
you can find the replacement parts to fix this problem at your local plumbing wholesale store.
Maax Calla 6042... | Answered on Oct 19, 2013
is there voltage going to the motor?
Rod
US Parts Center
Maax Calla 6042... | Answered on Jun 29, 2013
it sounds to me like the air button may not be working. You may have a small hole in the bellows which is the part that sends the air down the air tubing to the air switch in the motor. If there is not enough air being pushed down to the switch it will not activate the motor. You need a new air button or a new air switch in the motor. Pull the pump out and plug it into an outlet. take a straw and blow into the air switch while the pump is plugged in. it the motor turns on then you know you need an air button on the top of the tub. If the motor does NOT turn on then you need an air switch for the motor.
Maax Calla 6042... | Answered on Feb 21, 2011
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Maax Calla 6042... | Answered on Sep 05, 2010
Have you tried Mr.Clean Magic Eraser?
Maax Calla 6042... | Answered on Jan 05, 2010
This is often the capacitor charge on the side of the electric motor pump gone bad (which requires the whole motor to be replaced). check power to the motor with a volt meter. if you have power when you select the pump on, and no jet activity in the tub, then you have a bad motor.
Maax Calla 6042... | Answered on Nov 22, 2009
Maax Calla 6042 Bathtub - 101058-000 Logo
Popular Tags
27 questions posted
Top Maax Home Experts
US Parts Center
US Parts Center
Donni Steen
Mike
Are you a Maax Home Expert? Answer questions, earn points and help others
View Most Popular
Maax Home
  • Maax Home
Most Popular Question
maxx code e01 jets dont work
  • Home
