20 Most Recent Maax INFINITI HYDROMAX AIRPOOL II CORNER BATHTUB - 100055-012-W - White Questions & Answers
Found at http://www.maaxcollection.com/Produits/ProductInfo.aspx?cat=1&fmly=1315&mdl=1851&sp=2%3b5%3b215
Click on "Installation Guides" under the "Downloads" blue highlighted box. Then download the "Whirlpool Installation and User Guide".
Quite sparse on error codes, but p19-23 have some.
...soon to be owner/user Maax Infinity bahtubber
Maax INFINITI... | Answered on May 20, 2014
Not as easily done as you would expect. What is the Model number of the Control Box under the bathtub?
We need to know that before we can match up the sensor for you.
Rod
US Parts Center
888-521-6183
Maax INFINITI... | Answered on Feb 12, 2013
I will advice you check manualsonline.com or manualnguide.com to check for the manual you requested for.
Maax INFINITI... | Answered on Oct 20, 2010
good luck, designers must have thought they would last forever
Maax Home | Answered on May 23, 2019
I can't tell about your water supply from this posting. Is it possible you have iron or sulfur in your water that only shows up in the hot water? If so, you may not have drained the water heater often enough to prevent problems. Usually, draining it about every 6 months will do it. To drain the water heater, turn off the energy source (electricity or gas), turn off the inlet valve, and connect a water hose to the drain at the bottom of the tank. Open the drain ****. Some don't have handles and require a flat blade screwdriver to open them. Run the drain hose down the driveway so the hot water from the tank doesn't kill your lawn. By the time it reaches the street, it should be cooled off enough not to hurt anything. If it's been a while, you may want to weight down a trash bag at the end of the hose so the water and sediment coming out don't stain your concrete driveway. Let the water from the end of the hose dissipate over the trash bag. It takes about 30 minutes to drain a 40 gallon water heater. It goes faster to carefully open the overflow pop off valve to let air in while it's draining. When it's drained, close off the drain spigot, open the incoming water and when it is quiet again (full), turn the energy back on. You may have to relight the pilot or click the igniter until it flashes one time to let you know it's working. You should have hot water again in about 30 minutes. If the smell in the drain persists, some baking soda and vinegar flush will normally take care of that.
Maax Home | Answered on May 14, 2019
Does that model use an air switch to turn it off and on? You may have a loss of air compression in the switch linkage somewhere. It's not uncommon for those to fail after a few hundred compressions, especially if they were impacted sharply.
Look at these two web pages to see if they will help
http://www.fixya.com/tags/overload_reset_button/bath/maax
http://www.maaxspa.com.au/Maax%20Spa%202004%20Owners%20Manual.pdf
Maax Home | Answered on Jan 18, 2019
overload or insulation problems
get in an electrician to check with the appropriate meters
Maax Home | Answered on Oct 10, 2018
Maax INFINITI HYDROMAX AIRPOOL II CORNER BATHTUB - 100055-012-W - White Logo
14 questions posted
Top Maax Home Experts
US Parts Center
US Parts Center
Donni Steen
Mike
Are you a Maax Home Expert? Answer questions, earn points and help others
View Most Popular
Maax Home
  • Maax Home
Most Popular Question
maax hydromax tub temp control needs
  • Home
