If that's a BT (bluetooth) kb, you need to go to the tablet Settings, Bluetooth, turn on BT, you might have to tap the More link/button, locate the kb, and add it to get it to pair.
Is the keyboard flexible cable the same pin as the original keyboard? If yes and you are sure the new keyboard is okay, then you can change the language to the preferred language e.g US English, change its position to the first and make it referred. Its should work. You can also check online if there is any keyboard or input driver which when installed can be of help.
The easiest solution will be to locate a replacement laptop keyboard for that model. they arent hard to replace and usually cost between $40 and $80. I would web search HP Spare parts Third party is usually cheaper. Keyboards are pretty common replacements on laptops due to wear an tear. Most are replaced using a small phillips screwdriver. Its likley you can find removal instructions on the web as well (if they dont come packaged with the keyboard.
