Jenn-Air JGC8430 Gas Cooktop Logo
Posted on Jul 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have a 2008 jenn-air gas cooktop with 4 burners and want to change the white speckled glass top to a stainsteel top can I find a place to order this or can I have it painted under the glass
Anonymous
Level 2:
  • Expert 153 Answers
  • Posted on Jul 22, 2009
Anonymous
Expert
Level 2:
Answers
153
Questions
0
Helped
41574
Points
362
You can get it paint but the company which u buy u can fet a new top
1helpful
How to remove the top panel of the cooktop?
To remove the top so that you can replace the electrodes, you just need to pull all the burner grates off and knobs. Then remove all the burner caps and rings off so that all you're left with is the cooktop and the burner bases. There are screws going into each burner base. Remove all the screws and the burner bases will pull up and off and then you can pull the top of the cooktop up and off.
I have a Cooktop Jenn-Air Model JED8430. The cooktop glass is broken. Would it be possible to change only the glass? If so, where could I get an other one ?
Yes, you can change just the glass. It is called the maintop assembly and usually starts at $275 and goes up. You will need to get the remaining 3 digits for your particular model in order to get the right glass. A good place to start looking would be: http://www.searspartsdirect.com/partsdirect/part-model/JED8430?pathTaken=modelSearch&prst=0&shdMod=JED8430
Glass cooktop has cracked in two places
sounds like a stress fracture is your cooktop supported well
Stain on burners
Use DeBruce Polish on ceramic cook tops, go to debrucepolish.com
1helpful
Romvoing the top of my Whirlpool Cooktop
well usually you have to remove the knobs. thentake all of the caps off of the burners. sometimes there are scres that hold the burner caps on. make sure you turn the power off. Then after you have done this the glass should come right off. If not there may be screws under the cooktop. Do these first steps and let me know how it goes.
Glass Top Replacement
There are 3 or 4 screws under the front lip; then the unit hinges upward. Turn off the power first! Once opened you can safaly remove the burners and replace toe top. hope this helps!
Jenn-Air 30 in. JGD8130 Gas Cooktop
Yes. Buy a burner module. Sears sells them also most appliance part stores. (I am assuming you have the model with 2 knobs on the grill side) The electric version of burner modules is around $100 Gas should be similar price.
Wearing burner
no fix other than replacing the cook top with a new one
1helpful
Jenn-Air JGD8130 Gas Cooktop
grab hold of the installed burner cartridge at he top of unit and pry up slightly, should lift up without much effort, if not try lifting front side. they jsut lift up and slide back in no screws hold them in place
Top Jenn-Air Cooktops Experts
Paul Carew
Paul Bade
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
