Jenn-Air JED8430 Electric Cooktop
Take a brief Survey Take a brief Survey   Add to My Products Add
Problems with Jenn-Air JED8430 Electric Cooktop?
Troubleshooting and Support
Solved Problems for Jenn-Air JED8430 Electric Cooktop RSS Feed Post a New Problem
wiring problem
Our JED8430, Jenn-Air downdraft has a black, red, green, and white wire, but out of the wall only white, black, and...
1 Solution
Remove ceramic cooktop
Very simple question for those who know... How do you remove the ceramic cooktop from the unit to perform maintenance? ...
1 Solution
Need to convert a Thermador cooktop from...
Hello, I have a Thermador SGCS365RS 5 burner cooktop that I have purchased. I just found out after hooking it up and...
1 Solution
boiling liquid ran down into ignition...
We have a Jenn-Air electric cooktop Model 8430BDB. My son was making a pot of coffee and it boiled over into the knob...
1 Solution
downdraft fan not pulling test card down
vent fan not even pulling down test card down
1 Solution
JENN AIR GLASS TOP REPLACEMENT
THE GLASS TOP ON OUR DOWNDRAFT STOVE NEEDS TO BE REPLACED, AND I WANT TO ATTEMPT IT MYSELF.. CAN YOU PROVIDE THE STEPS I...
1 Solution
Jennaire jed 8430adb Cooktop
Serial nr 74009254. My fan switch sticks and sometimes will not go up and down and sometimes will not turn on and off....
2 Solutions
Unsolved Support Problems
Unsolved Problems for Jenn-Air JED8430 Electric Cooktop RSS Feed Post a New Problem
wire for stove top burners
Have a c202 Jenn-Air cooktop. Wiring from power supply input to the switches on the cooktop is tired where it connects...
Post a Solution
My jenn air cooktop only gets warm and...
I have a jenn air cooktop, model # cve4370w, and it has three places for elements. Only one of my elements gets hot,...
Post a Solution
Switch for cook top fan
I have a Jenn Air CP220 cook top control unit with a CM200 downdraft fan unit. The switch 71001494 fails after 3 to 4...
Post a Solution
tripping breaker
electric breaker tripped, attempted to reset and observed flash in one burner element. Any solution?
Post a Solution
crack in Jenn-Air stove top
I just found in a two-inch hairline crack curving along the edge of the cooking area (pan bottom) on my glass-topped...
Post a Solution
Dual Element
When I turn the dual element on High, either the large or small element, it does not completely turn red. There is a pie...
Post a Solution
Jenn-Air 4340B Cooktop Problem
Only the right front (large) burner operates. The lights indicate the other four are on but they do not heat. The one...
Post a Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
Fuel TypeElectric
Number of Cooking Elements4
Element TypeSmooth Top
Cooktop TypeFixed
Dimensions
Overall Depth22 in.
Overall Height4.63 in.
Overall Width29.75 in.
Warranty
Warranty1 Year
Jenn-Air Contact Information
Main support number1-800-688-1100
Sponsored Links
Loading problems.
Top Kitchen Cooktop Experts
tech17
6 solutions
Large Appliances
Ask Me
Guru
Eddie Re
6 solutions
Kitchen Cooktops
Ask Me
Wiz
amelisda
6 solutions
Large Appliances
Ask Me
Guru
Repair Service
Find Kitchen Cooktop Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
