20 Most Recent
Jenn-Air JGD8130 Gas Cooktop Questions & Answers
Stuck knob
if this is a oven you are lighting would be oven thermostat would contact surplyer as faulty goods dont try repair as will void garantee
The gas controllers on my jenn air cook top no
I just had the same happen, I called the technician. He just sprayed WD-40 on the shaft and with a pair of pliers went up down and turn (spray,spray) until it started working again, well that was 60$ I hope it helps someone
I am using propane for
You don't have the right Gas to Air ratio..... Not enough air to the burners or you are running to low of gas pressure for propane... Propane takes a smaller orfice or operate than Natural Gas.....
You should have 10" of WC for Propane operation..
You will need a manometer to check it.
The flame should be a blue color with no yellow in it. There should be air shutters right at the orfice to each burners. You will have to play with the adjustment to get the best blue flame with no yellow in the flame.... Hope this helps.....
Bought a 35 year old
Sorry to read about your problem, I hope this helps you out.
check to see if you have power to the unit, it has no pilot lite
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
