20 Most Recent
Jenn-Air JGC8430 Gas Cooktop Questions & Answers
One of burners can not
First you need to brush out the end tip of the sparking electrode and the burner metal part facing the electrode so they can create a spark. If not any result the you should remove electrode and check if the ceramic cover is broken and the sparking goes in wrong way and you will need to replace it.
Turn 1 on and other
Hi
After reading the question it seems that the issue is with the spark module however, please elaborate and post back for further assistance.
Daniel
All cook top burners spark when any is turned on
OK, the best action is to call for service, if the unit was just installed, and purchased. This unit should be covered at this time, by the manufactures warranty, or store 30 day warranty. This repair should be free. The culprit will be a faulty spark ignition switch, and module. Testing is required. Once this switch, or(module), is replaced, the unit will operate correctly.
Spark igniter doesn't arc
hi im gerbee fr.phil, much better to replace the part(igniter wire) coz that part cannot be repairable dont try to repair coz more dificult problem if u repair.to replace the part dismantle the unit or remove all the screw at the top of ur cooktop.before that unplug the unit fot ur safety.buy the part from the brand u carry.tnx i hope i help u
Jenn-Air Expressions Downdraft Gas Stovetop Model CVGX2423B - Unable to Get Nut Off Burner Base to Replace Igniters
It is possible to use WD-40 to help loosen the nuts, but it may not be enough on its own to remove them. Here are some steps you can try to remove the nuts:
- Turn off the gas supply to the stovetop and unplug the unit from the electrical outlet.
- Use a wrench that fits the nut snugly and try turning it counter-clockwise to loosen the nut.
- If the nut is stuck, try spraying a generous amount of WD-40 onto the threads of the nut and let it sit for a few minutes.
- After the WD-40 has had a chance to penetrate the threads, try turning the nut again with the wrench.
- If the nut still won't budge, try gently tapping the wrench handle with a hammer to help loosen the nut.
- If all else fails, you may need to call a professional technician to remove the nuts safely.
It's important to note that improper removal of the nuts could cause damage to the stovetop or cause a gas leak, which could be dangerous. If you are unsure about how to proceed, it's best to call a qualified technician to help you.
4/23/2023 7:31:56 AM •
Jenn-Air...
Answered
on Apr 23, 2023
