SOURCE: Where can I find an Jura Capresso Impressa F9 replacement lid
The only sources I have been able to find are in Europe. They do not always wish to ship to the US however. In the US the dealers always want the repair, but seldome wish to sell parts outright. Try this website for parts.
Mike
www.juraprofi.de
SOURCE: Describe your Jura Capresso Impressa Z5 Espresso
will start by itself after it was shutoff for after
7-12 hours suddenly ? Why
SOURCE: I have a jura capresso S7. I am finding water in
This is normal, after each cycle the brew unit will empty the drainvalve for excess water, this will ensure that the water used for each new cup is fresh from the watertank.
SOURCE: My Jura Capresso coffee maker is
The sieve in the brew unit is probably clogged, this means that it takes to long to push the water through the coffee. There is an automatic time-out on the pump that controls this. It also can be that your coffeeoutlet is clogged.
Try cleaning out any used coffeegrounds from the inside of the machine, use your finger up into the brew unit. If this doesn`t help, it needs service.
SOURCE: My Jura Capresso Impressa E8 is leaking water
I have the same problem with my E9 and I have traced it to the diaphragm unit that is just distal to the pump itself. Apparently, the diaphragm is secured with a steel band (not stainless since it is rusty) that may hold seals or O-rings that break down. You can observe it leaking when pressure applied during brewing. The question is: can a new unit be ordered and if so, where?
