20 Most Recent Jura Capresso 560 Electric Burr Grinder Questions & Answers
I had this problem and fixed it. At the bottom of the bean container is a tab that extends about a quarter of the way around. This tab is designed to fit into the base inside a quarter-circle groove that rotates back and forth slightly when the bean container is installed or removed. In my case, the groove on the base was not aligned correctly, so I inserted a blade screwdriver into the groove and rotated it gently in a counter-clockwise direction until it stopped. After this, I could install the bean container as expected.
Jura Capresso... | Answered on Jan 28, 2018
take it apart see if vents are clogged
or a part broken
Jura Capresso... | Answered on Apr 16, 2017
First of all the solution IS NOT in the manual. Second of all, you shouldn't go taking the grinder apart. It is soooooooo simple. You just have to rotate the black part where the long **** is counter clockwise until it's at about 2 o'clock. The blade slips right off. I saw a post about someone sending it in for repair for this same problem. It must be a lie because this is not a problem that needs a repair solution. It is a very simple fix. No tools no springs popping out at you, no nothing. Again, Just hold onto the black part with the ****. It moves. Turn it counterclockwise to about 2 o'clock. The blade slips off.
Jura Capresso... | Answered on Jun 21, 2016
I just took mine apart. The ball bearings go on top of the springs.
Jura Capresso... | Answered on Apr 18, 2015
I have a Bodum grinder and the screw was under one of the rubber feet. Not sure if your brand does too.
Jura Capresso... | Answered on Mar 09, 2015
Yes! I had the same issue with putting the burr in upside down and then twisting it an effectively "locking" it in there incorrectly. I tried the "knife" solution that worked for some people here, but it was placing the bean container back on and twisting counter clockwise that did the trick!
So glad I found this thread and didn't give up trying to fix my burr grinder (which we love).
Thanks to jaybayca!
Jura Capresso... | Answered on Feb 24, 2015
(Probably too late to be useful, but seeing as I just had the same issue myself...)
There aren't any screws holding the housing on. There are a few indentations around the base where you can insert something to pry. Just work your way around gently, and the housing should come off.
Jura Capresso... | Answered on Dec 14, 2014
I had the same problem with too fine a grind when I took mine completely apart to clean (including the lower burr). The solution I finally came around to was to further tighten the star-shaped screw which holds the lower burr assembly in place. I had originally just tightened it until the lower burr until the lower burr assembly started to turn with the screw, but that wasn't enough. So I held the assembly in place and tightened the screw further and I'm back to my previous grind coarseness/fineness.
Jura Capresso... | Answered on Mar 16, 2014
Jura Capresso 560 Electric Burr Grinder Logo
38 questions posted
Top Jura Capresso Coffee Makers & Espresso Machines Experts
markybean
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Jura Capresso Coffee Makers & Espresso...
  • Jura Capresso Coffee Makers & Espresso...
Most Popular Question
after removing cleaning drop in portion
  • Coffee Makers & Espresso Machines
