20 Most Recent Jura Capresso C1500 Espresso & Coffee Maker Questions & Answers
Used to get the Service 8 with increasing frequency until it almost froze up. Luckily I figured out an easy solution and my 5 year old refurbished C1500 with over 4000 coffees runs like brand new. Here's how:
Take out the grounds tray and reach in to pull back the flap up above where the grounds fall. There is a piston and cylinder thingy behind the flap kind of like a car piston. Take a wad of wet paper towel and shove it up there to clean it out. Then use a dry towel to dry it. Now the secret solution: Take a can of spray pam and point it at the piston and cylinder with the flap pulled back. Give it a couple good shots. Now you just need to get the machine to work that in between the piston and cylinder walls by running the rinse cycle until it frees up. You may have to run it a few times then unplug and let it cool for a couple hours and run it again. The motor overheats if the piston is really stuck so you need to let it cool down. Apparently this is lubricated at the factory with a FDA approved food grease from Dow Corning that needs to be replenished but hey no one is going to die from a little vegetable oil. Some day if it even hints at happening again (It has been 3 months now) I know what to do. Cheers!
Jura Capresso... | Answered on Oct 29, 2016
Hi, I made some videos how to fix your Jura step by step, good luck... http://fixandparts.wix.com/nicknicoloudis#!jura-coffee-machine/c15gy
Jura Capresso... | Answered on Mar 23, 2015
Hi Alan
Try Manual & Instruction Books On Line
The Books & manuals are more than likely on the manufacturers site.
They usually can be downloaded for currently available devices.
Search their support area for your specific model of device.
Try Google Search for a Manual or PDF File for the specific brand & model number.
Also check these Sites:
www.retrevo.com .... Manuals
www.office.manualsonline.com
Jura Capresso... | Answered on Mar 05, 2015
The "sensor" is most likely a micro-switch. When the tray is in it actuates the switch and closes a circuit indicating to the controller that the tray is in place. Sorry to tell you this but it will have to be disassembled to replace the switch if it has failed as the micro-switches are usually sealed items that are not normally cleaned.
Jura Capresso... | Answered on Nov 11, 2013
If the drawer is stuck and cannot be put back in then put everything back except for the coffee grind bucket. That works for me. Press the power button to switch it off and then back on again and you can removed the drawer and put the bucket part back in again.
Jura Capresso... | Answered on Dec 06, 2012
After making approximately 200 coffees, the internal brewing chamber and the
brewing unit must be cleaned (of coffee oils, etc.). The display will show
CLEAN UNIT alternating with the regular message. This indicates that it is time
to run the tablet cleaning cycle
Jura Capresso... | Answered on Jul 01, 2012
Have you tablet cleaned it?
Jura Capresso... | Answered on Dec 12, 2011
Jura Capresso C1500 Espresso & Coffee Maker Logo
41 questions posted
Top Jura Capresso Coffee Makers & Espresso Machines Experts
markybean
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Jura Capresso Coffee Makers & Espresso...
  • Jura Capresso Coffee Makers & Espresso...
Most Popular Question
c5 machine stuck
  • Coffee Makers & Espresso Machines
