Few weeks ago I have purchased an used car which is already installed this Kenwood as replacement for the genuine Audio system, I had tried many times to create new account as user but unfortunately this Kenwood need the previous owner password so I can access to operation system to setting to format the previous owner password but when I had contact the previous owner he refused to give his password because he has a personal files saved in it & up to date I cant access to this Kenwood & more over I had create account on (Rout Controller)which is adviced by this device itself as step to get access into system but as I said above the device demand on the previous owner password & the previous owner refused to give me. By the way I have read the manual I tried to format it by holding 4 seconds on red button but when the system lunch again is asking for the previous owner password. Thanks In Advance
Hi Mr. Khaled...
Thank you for choose the Fixya...
Kenwood music system are having the facility to reset the old user data from "Hard Reset" button, try to hard reset (Hard reset should delete the all data in Music system)
Kindly check the below link
Kenwood KDC BT30 Instruction Manual Removing The Faceplate How To Reset...
if it not solve your problem please send me your Kenwood music system model number so it is batter to find good solution.
Thanks
Prashant
SOURCE: System Restore / User Account Issues
hi there dell dimension 3000 systems are instalt whit symantec ghost if you wana restour to factory settings go to this link it's the best i have found http://www.goodells.net/dellrestore/fixes.htm
SOURCE: Dell Optiplex GX150 Factory Settings Restore Partition...
This is from the Dell support site. You were correct in pressing ctrl+f11 but perhaps you did not press at the correct time. If in following these first two steps you do not get the recovery console, it may not have been installed on your computer.
1 Turn on the computer.
2 When the Dell
splash screen appears during the computer startup process, press and
hold <Ctrl> and then press <F11>. Then, release both keys
at the same time.
3 In the Dell PC Restore by Symantec window, click Restore. Alternatively, press <Tab> to highlight Restore, and then press <Enter>.
4 When a warning message appears stating that all data will be lost, click Confirm, or press <Tab> to highlight Confirm and then press <Enter>.
The Progress window will appear. Once the restore process starts, Dell PC Restore by Symantec usually takes about 8 to 10 minutes to finish.
When the restore process is complete, the following message will appear:
The system recovery process was successful.
5 Click Finish or press <Tab> to highlight Finish and then press <Enter> to restart the computer.
The software is now installed as it was when the computer was first received.
SOURCE: need ethernet controller driver for ibm pc
http://www-307.ibm.com/pc/support/site.wss/MIGR-55830.html
all drivers manuals
