Nortel Norstar Plus Compact Ics Complete Phone System Lot Logo
E
Elaine Steele Posted on Mar 21, 2016
I get an error msg when trying to open voicemailbox inactive feature. How do I fix this?
1 Related Answer
Anonymous
  • Posted on Aug 08, 2009
SOURCE: Inactive feature when trying to get messages
How can I find out the extension Number of my phone set?
2answers
Messaging is inactive on all lines after push functions button and enter 981
Hi. Inactive feature often means that there's a problem with your connection to the call pilot. Do you have lights on your call pilot? Did you assign a mailbox to the extension you're working on? Did you remember to connect the call pilot to a station port?
Unable to access voicemail feature inactive
This means the system can no longer communicate with the voice mail. You can try to locate the voice mail and power cycle the unit to resolve the issue, If you still get inactive feature after the reboot you will need to replace the vms.
Our voicemail system is inactive but my phone says I have a MSG, how do I clear that?
You can have a (sort of text) message from one set to another without voicemail. Voicemail uses that mechanism to tell you you have a message. Feature 1 is Send message, Feature 65 is View Message, or press the soft key under the MSG display. After viewing it, another soft key should say ERASE.
Admin nortel i can't access the adminstrative programming. i enter feature 983 and it says "inactive feature". how can i fix it to where i can set up a new mailbox?
If you are getting inactive feature when entering feature 983 the phone system and voice mail unit are not communicating. This usually requires a power reset to clear. Or the voice mail unit is in trouble and a vendor needs to be called.
Feature Button
Sounds like the voicemail either is disconnected from the phone system or has lost power to the voicemail.Open the cover to the voicemail and see if there are any lights on in the system.If so then disconnect the power tho the voicemail for about 30 seconds. the voicemail could take up to 10 minutes to fully reboot.
2answers
I have tried feature 981, 982, 983 etc. and I get the message "Inactive feature". What is the problem.
First make sure u r using Voicemail system which is either Star talk or call pilot.
If u r any one of this then only u can use F 981, 982 , 983 or 985. Its a feature code of voice mail.
If u r using either of this and still gettin inactive feature, then try with rebooting The Satr talk or call pilot i.e. switch off from mains wait for few mins and switch it back on.
After rebooting it will take 15-20 mins to boot up the system and after that u can use these feature.
Thanks.
Abhi
Also trying to initialize voicemail, says Feature 983 inactive
Feature 983 gives cess to System Administration; This Feature will ask for a Log:
Feature 981 Opens A Mailbox your mailbox # should consist of three digits. First what is the name of your mailbox system?
1helpful
5answers
Inactive feature message displayed when we try to access any features on our M7310 phones. This occurred after a power outage.
Dear customer..here is the solution
Sometimes when you put a new (or alternate) voicemail system on a Norstar switch, The feature codes that accessed the old system stay in the KSU memory. If this is the case all of your feature codes will appear inactive even if the voicemail system is operating correctly.
To fix this issue you need to run an External Feature test (XFtest) to identify and remove the leftover codes from your KSU memory. You must have a programming set to access this menu (M7310, M7324, T7316).
Power down the Voicemail unit. Remove connection to voicemail ports from KSU.
1. Press [Feature] **938378 (XFtest). The password will be 266344 (Config).
2. Your display will read Feat code: and you will have options First and Exit.
3. Press First. The first stored feature code will appear, and you will have options Test, Back, and Next.
4. Press Test. Your options will read Remove and OK. Press Remove.
5. Once the feature code is removed, press Next to go to the next code.
6. Do this with all codes until your display reads None Registered
7. Release
Restore connections to the voicemail ports from the KSU. Power the system back up.
The feature codes will be restored to the correct defaults with the completion of the voicemail power-up cycle.
thank u
Voicemail
If the feature codes show as inactive, the phone system is not seeing the voicemail. Hopefully this has been fixed by now, but you may need to call in a Vendor.
3answers
Unable to open e-mail attachment
Open Files with .MSG File Extension Do you want to open a message with the Outlook .MSG file extension? The Encryptomatic MSG File Viewer makes it easy access Outlook MAPI message files (.msg files) created in Outlook 2000/XP/2003.
MSG Viewer reads .msg files encoded in western characters. It will display the text contents of the .msg file on your monitor. You can also print the message, save it to a text file, and extract file attachments.
Easy to Use Encryptomatic's Outlook .MSG Viewer is simple to use. It may be optionally installed as the default .msg file handler. This enables you to display a .msg file by simply double clicking it.
Extracts File Attachments from Outlook .MSG Message Files
Users can extract and save to disk any file attachments that were included in the Outlook .msg file, a useful feature not found in other viewers of this price class. To extract email attachments, just double click on the file attachment and save it to a directory.
viewer-screen.jpg What it Doesn't Do
The MSG Viewer is designed to give you quick access to an .msg file's text contents, file attachments and header information. It does not render colors, formatting or graphics, and it is not a full featured substitute for Outlook. With an RTF message with colored text and font formatting, the text will appear in black and white and the paragraph formatting will be lost (as in the message above). MSG Viewer displays only Western characters.
Top Nortel Computers & Internet Experts
MrFixitSTTL
MrTrekot
MrTrekot
Garatuss
Garatuss
Level 1 Expert
Are you a Nortel Computer and Internet Expert? Answer questions, earn points and help others
