20 Most Recent Nortel 1140E Questions & Answers
Try using 26567*738 as the default password for the 1120E and 1140E IP phones.
Nortel 1140E | Answered on Feb 03, 2016
here you are...
This could be the problem with your signaling server , have you checked it ??
I think it is losing connectivity of T-Lan Network.
1. Reset the phone by disconnecting and re-connecting power.
2. When the Nortel logo appears, press each of the four soft keys in sequence.
3. If no other configuration changes are required, press OK repeatedly until the “PC
Port? 1-ON 0-0FF
” option appears.
4. Press 1 to enable the PC Port or 0 to disable the PC Port.
5. Select OK to confirm the change.
6. Restart the IP Phone.
When the IP Phone is restarted, the firmware sets the PC Port status accordingly
You need to use an AC power supply on the base IP Phone 1140E for the backlight on the Expansion Module to work.
Nortel 1140E | Answered on Jan 26, 2016
Hello, depending on the status of the call the buttons will change automatically. Be aware that you may not be the initiator of the call so you may not have all the features. I hope this helps. If not you may contact me at: http://www.liveperson.com/nortel-guy
C1B is ancient UNIStim firmware. You cannot downgrade to it. Try converting to a more recent UNIStim version. You can download firmware from www.nortel.com/support.
Try a different phone on the same router, does that fix it?
should work, no problem.
Nortel 1140E | Answered on Oct 14, 2011
You need support from the manufacturer for the wireless headset. I hope this helps. If not please connect with me at: http://www.liveperson.com/nortel-guy/ for service and support.
Nortel 1140E | Answered on Aug 13, 2011
This sounds like there may be a problem with the button contacts on the circuit board inside.
If the warranty is still valid, you should return it to your place of purchase for a refund or exchange.
If the warranty has already expired and you are handy with a screwdriver, then you can try unplugging and disasembling the unit yourself.
Once you get the unit apart, look at the circuit board directly under the button pad. Check for any damage or cracks on the board itself, or if the button contactors in question are broken or displaced. Also check for any signs of corrosion or residue there and clean it off the circuit board with some Isopropyl Alcohol if necessary.
If you find any actual cracks in the circuit board, then the unit is like a total write off since you will be unlikely to find a source for just that part unless you get lucky and find something on EBay. There are complete replacement units currently available on EBay, but nothing for less than $100 besides this one auction item which is currently at $61 US:
http://cgi.ebay.com/Nortel-IP-Phone-1140E-Model-NTYS05-/360364935095?pt=LH_DefaultDomain_0&hash=item53e76c87b7
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information and items at the website indicated.
Thank you very much and good luck.
Nortel 1140E | Answered on May 11, 2011
Nortel 1140E Logo
55 questions posted
Top Nortel Computers & Internet Experts
J John
Vuk B
Are you a Nortel Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Nortel Computers & Internet
Most Popular Question
nortel 1140e
  • Computers & Internet
