20 Most Recent NorStar T7316E Corded Phone Questions & Answers
Dear Annabelle,
Is the machine call pilot 100 or 150.if 100 the 2 leds in your left hand side should be on also in your right hand side the middle led should be on same for 150 the 4 leds in your left hand side should be on.1) Try to unplug the power cable and re-connect it again.2) Make sure that the the output telephone cable [100 (2 pair) or 150 (4 pair)] depends on the device comming from the call pilot to the Nortel PABX connected properly from both sides. dont hesitate to contact me if you are facing any doubt.Goodluck and Kind Regards;
Ahmed Safaa El-DeebTelecom & Network Engineer
NorStar T7316E... | Answered on Mar 21, 2018
I would say you have all your mailboxes used up. See if you need all the mailboxes programmed up, maybe you can delete one from another user.
NorStar T7316E... | Answered on Jan 05, 2018
Contact your phone service provider or look on line for instructions from the phone manufacturer.
NorStar T7316E... | Answered on Nov 19, 2017
press feature * (star (shift 8)) 3, push the memory key (speed dial), then feature 0. This programs speed dial to that memory key.
NorStar T7316E... | Answered on Sep 25, 2017
On the set displaying the message enter feature #871.
NorStar T7316E... | Answered on Jan 12, 2017
You would have to call the phone company and have them block long distance calls.
NorStar T7316E... | Answered on Nov 22, 2016
Get Comcast we have a star feature that allows you to block numbers
NorStar T7316E... | Answered on Sep 30, 2016
You NEED to get SYSTEM documents (Hard Copy or CD)
for NORTEL NORSTAR CICS before TAMPERING ...URL posted below...
Found on page 24:
Default Password Code is "admin" on your phone dial... Done by pressing 23646 on your phone dial...
Time feature is accessed by inputting **8463 = (**TIME)
Hope this helps...
(CAUTION: read & understand BEFORE programming)
http://phone.manualsonline.com/manuals/mfg/nortel_networks/compact_ics_61_system_coordinator.html?p=24
NorStar T7316E... | Answered on Feb 04, 2016
Press Feature 985 - press 9 even when not listed in options. At the password prompt enter 73738767793 and answer the reset password prompt with yes. This will reset the password to default.
NorStar T7316E... | Answered on Dec 08, 2015
Does the two-line display say "Line in use" when you try select the line, or is the indicator next to the line button lit (so to speak), or both? First, try Feature * 0 then press each line key to see if they really are assigned to lines 2 and 3... they could be other functions or multiple appearances of another line.
NorStar T7316E... | Answered on Aug 27, 2015
to reset the administrator pasword enter feature 985 press 9, at the password prompt enter 73738767793 (resetsmpwsd) and press ok or #,press yes to reset password. password should be defaulted to 0000. then try Feature 983. if your system has 2 digit intercom #s your password is 120000 if your system has 3 digit intercom #s your password is 1020000.
NorStar T7316E... | Answered on Jun 29, 2015
Confirm the extension # you are working with and that the line 2 key is line 2. do this by pressing feature *0 and the pressing the intercom key, observe the display and then press line 2 key and view display. then go back in the programming and view line 2 apear&ring, change it until it is apear&ring, then release and check for working again. If this dont work check to see if line 2 is programmed as a private line.
NorStar T7316E... | Answered on Jun 28, 2015
693 questions posted
Top NorStar Lands Phones Experts
Marvin
Marvin
Thomas F. Schneider
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
  • NorStar Lands Phones
Most Popular Question
t7208 mailbox locked
  • Lands Phones
