20 Most Recent Nortel Business Series Terminal T7208 - digital phone Questions & Answers
I am using a Nortel T7208/T7316 sets (BCM 450 PBX) system, and I want to program a phone to ring when someone calls the main line. Most of our phones only ring when you type the extension internally.
The phone must be programmed with the target line assigned to the number you wish to have ring at that phone. This can be done with the BCM Element Manager interface. If your BCM450 is running version 6, I think this can even be done directly from the phone, but I'm not sure of that process.
2/24/2022 6:31:34 PM • Nortel Business... • Answered on Feb 24, 2022
2answers
Change display names
A problem with answering this question is first that the main SYSTEM keeps this info not the handset, so for the 3x8, 6x16, and 8x24 systems you can do the following (PROVIDED, the installer did not change the passwords to access).
Press FEATURE * * 2 6 6 3 4 4
Enter Password: 2 6 6 3 4 4 Display will read: " A. Configuration"
Press: NEXT Display will read: "B. General Admin"
(NEXT is always the button on the right of your lines/extension list, 2nd button down from top.)
4. Press: SHOW Display will read: "1. Sys speed dial" (SHOW is one key up from NEXT)
5. Press: NEXT Display will read: "2. Names"
6. Press the SHOW Display will read: "Set names"
7. Press: SHOW Display will read: "Show set:__"
8. Enter the extension number of which you wish to change the name Display will read: "<##:name>"
9. Press the CHANGE softkey
10. Using the dial pad spell out the name Ex: If you need the letter K press the 5 key twice and then press # to confirm the letter. Continue until the entire first name is spelled. (note: you are limited to 7 characters)
11. Press: NEXT (if you fail to do this step, the name will not be saved!!!)
12. Press the RLS key
I may be mistaken however I think you have to be on a model M7310, T7316, or M7324 phone (there should be at least one usually at the main desk) in order to program I don't think you can directly do it from the T7208.
Hope this helps.
2/1/2019 5:26:35 PM • Nortel Business... • Answered on Feb 01, 2019
2answers
Why does my nortel T7208 phone say mailbox is full but is not?
Try pressing the Feature key followed by "#65". We've also used this to clear phantom fax messages which Avaya Achillae (formerly Nortel Nancy) notifies via voice prompt when checking VM manually. If that doesn't work, you may need to delete/re-create the voice mailbox, which should completely reset the VM indicators for that box. Note: Assuming you're on a BCM system -- if you're testing VM by calling from one extension to another that has a "full" mailbox, calls may be refused or be forwarded to Call Center or Auto Attendant (if either are set up on your system). BUT, calls from outside may still get to VM just fine. I'm told this was by design.
10/6/2015 7:53:02 PM • Nortel Business... • Answered on Oct 06, 2015
0answers
Message waiting does not show on the LED (but did previously)
Did the messge waiting light work before?
Does the light flash when there is an incoming call?
try this... FEATURE # 8 0 6
this is a code to shut off the Static Time and Date feature on the set. Usually if this feature is turned on, the set does not flash where there is a message.
Well that is one thing, or the port maybe bad, and a technician maybe required to move that phone to a new port on the phone system.
7/17/2013 2:38:33 PM • Nortel Business... • Answered on Jul 17, 2013
4answers
Access voicemail from Nortel T7208
Have you set up the voicemail before?
OK, from your set;
-> dial FEATURE 9 8 1 (this is the code to get you to the voicemail)
-> then your passcode, if you never set up the voicemail, the temporary password is 0 0 0 0 (four - zero's).
-> if this is a new installed voicemail, the telephone system will tell you al that you need to initiate the voicemail box.
6/19/2013 5:26:27 PM • Nortel Business... • Answered on Jun 19, 2013
0answers
Nortel T7208 phone will not let me change password-locked
You can obtain the manual for this phone at the link below, which may help you reset the password.http://phone.manualsonline.com/manuals/mfg/nortel_networks/nortel_business_series_terminal_t7208_nt8b26aabn.htmlCisco 48V Telephone Power Supply
12/19/2012 4:29:05 PM • Nortel Business... • Answered on Dec 19, 2012
How to program nortel T7208 to have feature > 981 with an "other" option
After entering the mailbox access F981, press "#", the display should change from Pswd: to Log:. Now, enter the alternate mailbox number followed by the password for that box and "#". The remainder of the prompts should be the same as accessing the 'native' mailbox.
11/20/2012 3:46:15 PM • Nortel Business... • Answered on Nov 20, 2012
How can i remove the "do not disturb' features in my phone Nortel T7208
hey i have the solution. push the function button, then pound, then 85. hopes this helps. i had the same problem and i worked for me
9/13/2012 3:24:20 PM • Nortel Business... • Answered on Sep 13, 2012
My phone displays forward>0 and
on your nortel phone; press "feature # 4" and it will be cancelled.
8/29/2012 8:34:12 AM • Nortel Business... • Answered on Aug 29, 2012
Nortel Business Series Terminal T7208 - digital phone Logo
109 questions posted
Popular Products
Top Nortel Computers & Internet Experts
MrFixitSTTL
MrTrekot
MrTrekot
Garatuss
Garatuss
Level 1 Expert
Are you a Nortel Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Nortel Computers & Internet
Most Popular Question
phone displays forward gt 0
  • Computers & Internet
