MAGIC CHEF FRIG TICKS LIKE A KITCHEN TIMER SOMETIMES BUT I THINK ONLY WHEN THE COMPRESSOR IS OFF. FRIG IS 15-20YRS OLD. IT STILL WORKS BUT RECENTLY NOTICED THIS.
Hi, You can start with replacing the start capacitor and relay to see if the compressor will run again, but you have about a 50 -50 chance that the compressor has gone bad and will need to be replaced....
if the compressor is running your ref. should be getting cold.their is a defrost timer but when it is in defrost the compressor shuts off.I think you do have a leak.
From my earlier post, our compact Magic Chef 'frig was not running at all. It still looks perfect, so decided to check on the repair. It turned out to be the "starter switch," I think is what the switch was called. The repairman said this is a very common problem, so he had the switch we needed in his truck. It was repaired quickly and is running great.
Cost was about $140, part plus labor. A replacement would have been only a few dollars more, but would take more time and effort. FYI, the compressor on these Magic Chef refrigerators has a 5-yr warranty.
Hope that helps someone.
Jaci
Sounds like a defrost problem. Check to see if
there is any frost buildup in the back wall of the freezer. If so, it is not
defrosting as it should.
possible causes:
bad defrost timer
bad defrost heater (in freezer)
bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice
melt in the freezer overnight with the door open. Then try it the next day, if
is cooling fine then you need to have a service person replace one of the above
items.
