20 Most Recent Magic Chef CTB1922 Top Freezer Refrigerator Questions & Answers
Magic chef not cooling
The compressor is shutting down because it is drawing too much power and overheating. The clixon detects this and shuts off all power till it cools - then it resets and supplies power back to compressor until it overheats and problem repeats itself. So what is responsible for overheating? Well, if there is an obstruction in the cooling system (high pressure side), the compression goes up past spec and the motor labors and slows down, creating less back emf, and increasing current consumption > then overheats and turns off. OR, if some of the the motor windings have had the insulation melt off, then the motor has less resistance than designed, more current goes through and again it overheats and shuts down. In this case your motor is fubar and needs to be replaced.
4/24/2017 5:25:43 PM • Magic Chef... • Answered on Apr 24, 2017
What year is magic chef model ctb1922grw refrigerator?
There should be a sticker in the FRONT door that has the YEAR manufactured. ENERYSTAR has been around for quite some time. The newer the more efficient but still efficient.
4/5/2014 8:08:06 AM • Magic Chef... • Answered on Apr 05, 2014
No power to light bulb socket - how to remove controls cover to test?
There are 2 or 3 screws that hold the cover in place.
11/27/2012 10:44:04 PM • Magic Chef... • Answered on Nov 27, 2012
My small (5 feet tall) Magic Chef refrigerator has
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
NOTE: This
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Thanks
for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
8/14/2011 7:29:20 PM • Magic Chef... • Answered on Aug 14, 2011
My magic chef rb193p fridge wont stop running. I
I had the same problem. When the evaporator heater stops working, frost will build up until there is no air flow to the refrigerator. This will cause the refrigerator to keep running. Remove everything from the freezer and remove the pan at the bottom and see if there is a frost buildup. .... Bruce
7/29/2011 3:42:35 PM • Magic Chef... • Answered on Jul 29, 2011
Freezer is not freezing, fridge cooling. cleaned
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
7/8/2011 9:05:26 PM • Magic Chef... • Answered on Jul 08, 2011
The refrigeator just flat doesnt work
heatman101
4/30/2011 7:18:48 PM • Magic Chef... • Answered on Apr 30, 2011
Freezer working but refrig fan
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
4/26/2011 3:28:56 PM • Magic Chef... • Answered on Apr 26, 2011
Refrigeraor is running but the freezer part is
heatman101
4/20/2011 11:55:16 PM • Magic Chef... • Answered on Apr 20, 2011
2answers
Refrigerator bottom is not working well. the
Your defrost terminator and heater are where the problem lies. The evaporator coil is probably iced up. The ice is acting as an insulation shield. So the freezer will remain cold, but not as cold as it should be. Unplugging the refrigerator and letting it defrost, will solve the problem temporarily. The refrigerator will work for a couple days. But the root of the problem will still need to be fixed.
2/27/2011 3:19:20 AM • Magic Chef... • Answered on Feb 27, 2011
Fridge is freezing all liquids freezer is turned
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
2/24/2011 3:48:45 AM • Magic Chef... • Answered on Feb 24, 2011
Does not get cool
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.If your refrigerator is running but warm, then...Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...Refrigerator Condenser Coil Cleaning Refrigerator RepairRefrigerator Troubleshooting Refrigerator CompressorRefrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Coldheatman101
11/19/2010 5:17:12 AM • Magic Chef... • Answered on Nov 19, 2010
Magic Chef CTB1922 Top Freezer Refrigerator Logo
56 questions posted
Top Magic Chef Refrigerators Experts
Kardoc
vince
Paul Carew
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Magic Chef Refrigerators
Most Popular Question
  • Refrigerators
