20 Most Recent Magic Chef (CSD2610KRW) Top Freezer Refrigerator Questions & Answers
Ice maker water valve
Check the water inlet hose for a kink first.
11/22/2013 8:46:53 AM • Magic Chef... • Answered on Nov 22, 2013
Magic chef side by side ref side at 40 deg freezer
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
9/19/2011 2:39:19 AM • Magic Chef... • Answered on Sep 19, 2011
Our side by side Magic
What is the model number of your unit?
Richard Roth
The FixYa Team
8/11/2011 2:30:59 AM • Magic Chef... • Answered on Aug 11, 2011
Installed a model# UKI1000AXX ice
Yes you can check the voltage to the valve, but first a word of caution. To start the icemaker and let it cycle so toward the end of the cycly power will be sent to the valve, THE ICEMAKER MUST BE STARTED USING A JUMPER WIRE AND THIS COULD BE DANGEROUS AND RESULT IN YOU BEING SHOCKED IF NOT DONE CORRECTLY. If you chose to proceed and check for power to valve;
remove front cover of i/m
usea jumper wires about 16 or 18 gauge and strip both ends so about a 1/2" one wire is bare on each end
place bare ends into holes on icemaker front marked as T & H
the main gear will start moving,the jumper wire may have to wiggled to get a good connection
once gear moves and within 10 seconds you will hear a click REMOVE JUMPER WIRE AS SOON AS CLICK IS HEARD
the fingers on icemaker will rotate in a 360 degree rotation,if you think of the fingers as the small hand of a clock in about the 10 to 12 o'clock position their should be 120 vac at water valve if i/m is good. if 120 vac present replace water valve, if 120 vac not present replace icemaker
8/10/2011 3:36:37 PM • Magic Chef... • Answered on Aug 10, 2011
The motor is very loud.
If its the motor in the freezer that is the evaporator fan motor, if the motor is the black thing on the back that is the compressor. If the comp is making noise this means its about to go out. The fan has a bearing and when it goes bad can cause this issue.
http://www.appliancerepairlesson.com/
3/6/2011 12:57:50 AM • Magic Chef... • Answered on Mar 06, 2011
My refrigerator first stop making
Don't know much about magic chef but you might want to check the water filter,if it has been in there for more than 4 or 5 months it might be clogged depending on your water.If this does not help repost your ?
3/1/2011 1:06:06 AM • Magic Chef... • Answered on Mar 01, 2011
May i know how many cu ft is this type of ref?
26 cubic foot
10/27/2010 4:16:45 AM • Magic Chef... • Answered on Oct 27, 2010
Magic chef side by side not keeping cool around 50
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
arha46w
9/29/2010 9:20:43 PM • Magic Chef... • Answered on Sep 29, 2010
Ice maker won't work, it worked fine for 15 hrs,
Check water spout to make sure it's not frozen up. If it's not frozen, it's likely your icemaker is bad. ...could be the valve too.
9/26/2010 3:54:28 AM • Magic Chef... • Answered on Sep 26, 2010
Tengo un frigorifico Magic chef
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
9/11/2010 11:59:45 PM • Magic Chef... • Answered on Sep 11, 2010
Top freezer and refridgerator not maintaining
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
9/11/2010 10:45:57 PM • Magic Chef... • Answered on Sep 11, 2010
Lights come on fan blows air thermostat is on. but
say nothing is yet solved... pls do check.. temp switch attached to the evap fins .. it may malfunction...though i assume that you heard and confirmed that the compressor is running fine ..and condenser is producing hot temps.. god speed bro..
9/9/2010 12:37:50 AM • Magic Chef... • Answered on Sep 09, 2010
Actually a side by side freezer's way cold but
ck the dampner control as it controls the air flow to the fresh food side. also see if the evap fan is working .. inside the freezer side . this blows the cold air to the fresh food side. mm
8/10/2010 5:28:37 AM • Magic Chef... • Answered on Aug 10, 2010
Magic Chef (CSD2610KRW) Top Freezer Refrigerator Logo
Popular Tags
57 questions posted
Top Magic Chef Refrigerators Experts
Kardoc
vince
Paul Carew
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Magic Chef Refrigerators
Most Popular Question
may know many cu ft type ref
  • Refrigerators
