Whirlpool WRF560SEYM Logo
D
Dave Posted on Mar 13, 2016
What is causing fan blade in freezer compartment to hit something?
Eliminated Condenser fan
2 Related Answers
Mike Inman
  • 219 Answers
  • Posted on Mar 19, 2009
SOURCE: ice accumilation next to fan in freezer compartment
u have a defrost problem need to replace heater and tstat
Anonymous
  • 1606 Answers
  • Posted on Jul 19, 2009
SOURCE: Fan Noise coming from back of freezer compartment
Check the door seal to ensure outside air not being pulled in . You could have a defrost problem if frost build up on rear freezer wall .
Samsung RB31F Fridge/Freezer - fridge temperature too high, freezer OK
1-The condenser coils are usually located under the refrigerator. They dissipate heat as refrigerant passes through them. If the condenser coils are dirty, they won't dissipate the heat effectively. As debris builds up on the coils, the refrigerator becomes less efficient, causing the refrigerator to work harder to cool down. If the coils are significantly dirty, the refrigerator will not be able to maintain the proper temperature. Check the condenser coils to determine if they are dirty-if the condenser coils are dirty, clean them.
2-The evaporator fan motor draws air over the evaporator (cooling) coils and circulates it throughout the refrigerator and freezer compartments. Some refrigerators have more than one evaporator fan motor. On refrigerators with only one evaporator, the evaporator is located in the freezer compartment. If the evaporator fan is not working, it will not circulate the cold air to the refrigerator compartment. If this occurs, the freezer may still get cold, while the refrigerator will not get cold. To determine if the evaporator fan motor is defective, try turning the fan blade by hand. If the fan blade does not turn freely, replace the fan motor. Additionally, if the motor is unusually noisy, replace it. Finally, if the motor does not run at all, use a multimeter to test the motor windings for continuity. If the windings do not have continuity, replace the evaporator fan motor.
Banging noise
Usually the condenser fan blade hitting on some part of the condenser or shroud.If you can access it, check the fan mountings, and blade for straightness.
Maytag refrigerator / freezer compressor fan not running and some items in freezer appear to be thawing
Check to see if the fan mount bent somehow. The fan blade just might be jammed. If not see if the fan is getting power. The unit will not cool properly if the compressor and condenser are not being cooled down by that fan.
Noisy freezer compartment
The only thing that produces any real noise in the freezer is the evaporator fan. Its possible that the fan blade has either broken or hitting something as it spins, or the mounting has broke, If you could describe the noise maybe I could give you a more accurate answer
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
My fridge is making a lot of noise. It does not stop. What might the problem be? Model# 2539668010 Serial# BA62202425
This is a basic no frills refrigerator so that things that can make a lot of noise is limited. And where you say it doesn't stop, then it is most likely a fan. You have two one in the freezer compartment that could have accumulated some ice on the blades which could through it out of alignment. So it might be hitting the sides of the case.
The other fan is underneath your cabinet, and blows air across the compressor, and condenser coil. If there is a lot of lint or debie in this area then the fan blades could be come coated and then the out of balance condition could cause noise.
If a cleaning doesn't fix the problem then you will probably have to replace the fan blades and motor.
7helpful
2answers
The fan is making too much noise
Hi. You didn't state which fan you are having issues with, so i will address both areas.
The condenser fan is located behind the refrigerator. It may be necessary to remove an access panel to reach it. This fan has a shroud, and if the fan blade becomes warped, it will rub against the shroud, causing noise. This fan blade is whole,and it can be removed and replaced if this is the case. Ok, the next problem spot will be the evaporator fan.
The evaporator fan is located at the back of the freezer. It may be necessary to remove obstructions such as the contents of the freezer, freezer shelves, ice maker and the rear inside panel of the freezer. The rear panel may be held in place by retainer clips or screws. Remove the screws or depress the retainer clips with a small screwdriver. Check the fan for warped blades. If the blades are warped or mis-aligned, replace it. This fan also is protected by a shroud as well, and it will make noise if the fan blade is damaged.
NOTE_ If the fan blades are not warped, and rubbing against the shrouds, this will indicate that the motor that rotate the affected fan is damaged. It must be replaced, in this case.
I have a Sunsung RS21JLSG, and it's not chilling the food like it should. It's making terrible noise, sounds like a generator. Anyone know the problem?
Fan blade is hitting something probably, could be ice buildup in the freezer compartment. Open the freezer door and see if thats where your noise is coming from. If it is coming from the back of the refrigerator at the bottom could be something was drawn into the fan causing you noise.
3answers
Rs2360ww hot to the touch
yellow pine ..when your compressor is running the condenser fan should also be running. located next to compressor. clean coils and replace condenser fan.
2answers
Amana bottom refrigerater
huthy, the fact that it's lasting 15 to 20 seconds leads me to believe that it could be one of the fan blades hitting. The valve springs on the compresser would make more of a clunk-clunk noise and wouldn't last that long. The evaporator fan in the freezer compartment has a grille that will snap on and off, clip on the bottom and tabs on the side. See if you can remove the grill and check to see if there is any ice build up around the evap. fan. The other fan, condensor is in back by the compressor, it could be hitting on the shroud upon start up or shut down. Check these things first and post back...Catriver
Top Whirlpool Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
