20 Most Recent Woods 201 cu. ft. Upright Freezer V2003RW3 Questions & Answers
May I get the make and model # to help you more.
Woods 201 cu.... | Answered on Dec 21, 2014
Usually the condenser fan blade hitting on some part of the condenser or shroud.If you can access it, check the fan mountings, and blade for straightness.
Woods 201 cu.... | Answered on Apr 26, 2014
If the only fault was the door left open, switch off and defrost completely for 24 hours. Clean condensor coil. Restart and run for 12 hours before checking.
Woods 201 cu.... | Answered on Aug 08, 2012
Sorry to read about your problem, I hope this helps you out.
sound like you are low on freon
I tried to help you.
Please help me and Rate/Vote on my response, thanks and good luck
Woods 201 cu.... | Answered on Dec 24, 2010
igloo is cold snowflake is warmer.
Woods 201 cu.... | Answered on Oct 04, 2010
That is the thermostat switch. You should be able to control the inside temperature by rotating the nob.
The defrost time clock is not working Get a new one at an appliance parts store
Woods 201 cu.... | Answered on Sep 16, 2010
You have a plugged drain hose. Defrost unit then check drain hole to see if clear. These have a real problem with that. This company is out of buisness now.
Woods 201 cu.... | Answered on Aug 28, 2010
Empty then unplug for 24 hours or so.
To speed it p a tad - you could use a hair dryer directly on the evaporator coul.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Woods 201 cu.... | Answered on Aug 26, 2010
Every Refrigerator has its own "personality" There is no common
setting for any one refrigerator. I would start with 3
The real solution is what I have always told my customers
Get a refrigerator thermometer and a freezer thermometer
Refrigerator temp should be about 33-37 degrees.
Freezer should be about 0-10 degrees. below 0 is overkill
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Woods 201 cu.... | Answered on Aug 07, 2010
Hi, The defrost heater may not be working properly (timer stuck, heating element burned out, bad defrost thermostat,etc.). The unit should go into defrost mode about every 6-8 hours typically and last about 30 minutes (depending on model of freezer). During defrost cycles the compressor and fan do not run (don't want to keep cooling while trying to defrost). Once defrost is over, the fan and compressor get power again.
Take care
Woods 201 cu.... | Answered on Jul 17, 2010
im not sure if i answered this one before. but this sounds like a blocked drain, the drain is located midway behind the shelves, you can take away the catch tray and poke a coat hanger down this hole hole to dislodge the blockage.
Woods 201 cu.... | Answered on Jul 12, 2010
Woods 201 cu. ft. Upright Freezer V2003RW3 Logo
Popular Tags
39 questions posted
Top Woods Freezers Experts
Gil Shultz
Andrew Taylor
Andrew Taylor
Are you a Woods Freezer Expert? Answer questions, earn points and help others
View Most Popular
Woods Freezers
  • Woods Freezers
Most Popular Question
defrosted 210 cu ft upright freezer
  • Freezers
